Home > Maintenance & Mods (L322) > NO power (not limp mode) idle at 500rpm - now non starter .
Page 1 of 8 12345678>
Kevhdkent
2008 TDV8 3.6
Close to giving up Sad after a month of failed diagnostics.
Cruising at 50/60mph with trailer, uneventful no issues for 150 miles, then suddenly rpm drops to 500 and complete loss of power with no throttle response. BUT IT DOES NOT CUT OUT.
Cruise, NOT coast, 1/4 mile into a lay-by where she sits at a very low 500rpm idle, no throttle response, until I turn her off.
Never to start again Big Cry
To be clear, there were no pops or bangs grinds mechanics sounds or lumpiness in the running, just low rpm & no throttle response.
The recovery engineer, 2 auto electricians, and a mobile mechanic all raise their hands in defeat declaring “it should start & run” !
Fuel lift pump checked & good.
Rail pressure checked & good.
Air induction good.
Fuel pumped out, purged, and clean fuel added.
ps (a big PS) It won’t fire up with Easistart direct to the throttle bodies ???
pps On initial crank it may make up to 750rpm but then immediately dies.
Hoping someone can make sense of this. PLEASE
Post #610656 27th Oct 2021 6:19pm
Mikey
Does it start with the top turbo hoses off?
Post #610657 27th Oct 2021 6:25pm
Kevhdkent
Thanks for a quick response, any help appreciated.
As stated the car has never started since the loss of power a month ago.
Are you suggesting I should attempt to start without the turbo hoses connected ?
I have very little mechanical knowledge of these cars and no idea what part the turbos might play in start up.
Post #610670 27th Oct 2021 6:59pm
You need someone with proper diagnostic equipment for a Range Rover, not the generic type you find at most garages, find a good Land Rover independent garage near you and get them to take a look...
Guessing and just changing stuff by guess work will just waste money... you need someone with experience of these to understand the results they will get from an in depth diagnostic...
Good luck... Pete
Post #610735 28th Oct 2021 8:43am
Kevhdkent
Thanks for your input Pete.
I have had 2 auto electricians, and a mechanic, all recommended by RR owners who have not been able to identify a cause.
My first issue with taking it to anywhere is that being a non starter there is the expense and logistics of getting it to said specialist without any guarantee of a correct diagnosis.
If I’ve got “simple” question it would be,
Why would it (or any Diesel engine) not fire when spinning over and pumping easistart down its throats ?
I’d be happy to hear any thought thru suggestions.
Post #610767 28th Oct 2021 12:24pm
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Lack of compression / inlet valves not opening. If the easistart makes it into the cylinder and you have sufficient compression, it will fire. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #610790 28th Oct 2021 2:26pm
Sounds like you need someone to do basic checks, compression would be the first as AJ suggests... Thumbs Up Pete
Post #610791 28th Oct 2021 2:34pm
Kevhdkent
Thank you both for your replies.
Like you, my belief is that is that if a Diesel engine (any Diesel engine) is provided with a fuel source and air (atmospheric direct to the intake throttle body) it should fire.
So, if compression is the only thing missing can we explain why all 8 cylinders suffered lack of compression at precisely the same time, but continued running at a low, but smooth & consistent 500rpm ?
Beats the hellout of me !
Post #610828 28th Oct 2021 5:59pm
Mikey
Yes. Check the oil level beforehand though Thumbs Up
Post #610864 28th Oct 2021 8:42pm
GraemeS
Use a suitable diagnostic device to check for crankshaft position sensor activity. Nothing from that sensor and the engine will not attempt to fire because the ecm won't know that it's turning over. The camshaft position sensor is another although there should be fault codes stored for that sensor.
Post #610880 29th Oct 2021 1:23am
Fox889
Perhaps give Martin Hind at Dartford Transmissions a call & bend his ear for 2 minutes & see what he says?
Hope this helps & keep us in the loop if you don't mind. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #610892 29th Oct 2021 7:06am
Kevhdkent
Hi, I have an engineer looking at it on Monday and will ask he check this.
if the crank position sensor was malfunctioning would it rise to 750rpm on initial crank before dying as noted above ?
Post #610975 29th Oct 2021 5:32pm
AJGalaxy2012
It should still fire with easystart squirted in, thats not happening so the only thing it can be is lack of compression. BMW i3 Electric Car
Post #610985 29th Oct 2021 6:36pm
GraemeS
One would expect at least an attempt to fire even if the sensor then immediately malfunctioned.
Post #610999 29th Oct 2021 7:44pm
AJGalaxy2012
The sensor is irrelevant when easy start is used, the fact that it’s not firing then suggests low compression. Reading back on the thread it would seem possible that the timing may have jumped teeth and possible valve damage? Wouldn't rev to now it won’t fire, just a thought. BMW i3 Electric Car
Post #611001 29th Oct 2021 8:15pm
