Home > Technical (L322) > Intermittent Suspension Fault but No Codes? |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2475 |
Has your IIDtool been configured to show all faults? I can't recall the specific type of fault that ex factory hasn't been selected but Pending comes to mind. |
24th Oct 2021 7:47pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
I would have a go at recalibrating your EAS system with the IID, this may cure it, if not it is probably a sensor or the wiring to one of them, live values with the IID and remove and move the rods to check they are working OK... Cheap checks to do and may give you a solution.. Pete
24th Oct 2021 9:28pm |
RR2B Member Since: 04 Aug 2020 Location: Rowlands Castle Posts: 251 |
Thanks for the replies. EAS was recalibrated about 6 weeks ago, after which no faults came up for about a month. Now back to square one with the pesky intermittent 'cross articulation algorithm' issue. I assume a dodgy ride height sensor would come up with a specific fault code? In the absence of this I am erring towards a dodgy wiring connection. Can IID help identify?
26th Oct 2021 9:23am |
