![]() | Home > In Car Electronics (L322) > 2010 to 2012 satnav information gathering |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35608 ![]() ![]() |
sounds good and apparently a bloke in bulgaria can do the same with the L405 nav system but did i read right thats its only 2017/2018 mapping? ... - .- -.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7897 ![]() ![]() ![]() |
Excellent job. I follow that…. And agree it’s not for novices…. Though you could always get a second hand unit and upgrade the maps on that… before you touch your own car…..
i just updated my wince igo sat nav to 2021 q2 mapping..can these maps be used if wince can be the base firmware? ... - .- -.
Cudman Member Since: 28 May 2018 Location: Undisclosed Posts: 15 ![]() ![]() |
Honestly don't know if the maps can be used, simply because I haven't tried. I am 99% sure the firmware from WinCE will not work as none of the threads I've read on the MMM2 system state that it is WinCE based. Also, the firmware seems vendor specific as the Volvo firmware on the DVDs must be replaced by Land Rover's version. Out of courtesy, here is the Volvo map download portal : https://www.volvocars.com/uk/support/downloads/maps As far as I can conclude its the RTI 2008 maps distributed on DVD that are a 100% match with the FFRR 2010-2012 system. And a bonus treat: I've already concluded without a doubt that the Sensus 2011 download is 100% identical with the USB based update for LR4/Discovery 4 USB updateable nav systems used in model year 2014 (don't know the full MY range of that system) bar the LOADING.KWI file which must be replaced with the one from LR. Oh, and there are three files with zz0 and zz1 extensions that needs to be concatenated together before being used, and the resultant file given the KWI extension. I've yet to take out the drive and manually update it as again, the drive will be password locked. A topic for another forum ![]() I did test those maps in my FFRR and no, they are of a different format and made the nav computer reboot constantly. |
ASH Member Since: 05 Jul 2018 Location: Staffordshire Posts: 15 ![]() ![]() ![]() |
Ive actually brought a new hdd to fit into my nav unit, so if I can download the files, put them onto the new hdd, then strip my dash out, and swap the old hard drive for the new one, do you think this would work?
If the new HDD has ATA Security it might work, is it the exact same model as the one in the nav unit, or what is the model number of the drive? I could look up in the spec sheets if it even supports the needed disk security.
plese see attached pics, of the screen showing me what's installed & the new hdd
Good news is that the drive according to the online spec sheet I found here: https://www.manualslib.com/manual/540144/S...=21#manual does indeed support ATA Security. The potential bad news is that the environmental parameters of this drive is nowhere as good as the Hitachi Endurostar drive already in the navcomputer, for example operating in cold weather or sustaining shocks when you're driving. See here more on why Hitachi claims these drives are built like a tank https://www.asipartner.com/marketing/surve..._N4K50.pdf
Might just try it to see if it'll work.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
would someone be able to clone a batch of HDDs? group buy kinda thing? . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
Well they are available in bulk from China ![]() If somebody does get out their nav HDD I'd love to get a sector image of one to analyze further differences between regions, and possibly work out what it takes to load a map onto a car where the original license files are gone, like from after a HDD failure. |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2641 ![]() ![]() |
I'm keen to go down this path but not for a couple of months and providing that I can get hold of a computer with IDE support and can get late enough maps for my part of the world to be worthwhile. |
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1099 ![]() ![]() ![]() |
Just to throw a hat in the ring -- I have a 'spare' head unit complete with drive (obviously)
Do you know if a USB to IDE adapter doesn't work to remove the master PW? |
