![]() | Home > Maintenance & Mods (L405) > Brand New Autobiography windscreen fogging up whilst parked |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 775 ![]() ![]() ![]() |
There's water somewhere in the car.
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 453 ![]() ![]() ![]() |
Check the carpets aren’t wet. As mentioned there’s a significant amount of water getting into the cabin Christian.
Hoyboy Member Since: 21 Oct 2021 Location: London Posts: 73 ![]() ![]() |
Yeah I’ve looked everywhere I can think of in the car but can’t find any water / anything wet. The carpets are bone dry as well. Bit puzzled by what’s causing it. |
Check the coolant level (heater matrix could be leaking) and the air intakes under the bonnet - can get full of leaves and crud on other cars, not sure if RR’s suffer but worth a look as the leaves can cause rain to flow in behind dash Christian.
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2592 ![]() ![]() |
If it had been stood outside for a bit it could just have a lot of condensation inside - mine has steamed up when parked somewhere sheltered for a while. I’d see what happens after a long drive to clear it out. |
Ok thanks will do. Will check in the morning when I can see properly Last edited by Hoyboy on 21st Oct 2021 9:43pm. Edited 1 time in total |
Yeah it lives outside on the driveway. It was driven yesterday and it steamed up a lot when driving it but I put it down to it raining and people sitting in the car etc. but it had cleared up by the time I got home. After a day of it sitting there it’s just steamed up by itself again with no one in it. |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 751 ![]() ![]() |
Is the AC working? |
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 ![]() ![]() ![]() |
Just to build on Cass comment - are you running the AC? If not make sure you are for the next few trips as the AC will take moisture out of the air and start to dry out the car.
Just had a look and there’s nothing leaking or any leaves etc |
Tbh no we haven’t really used the AC. Only times it’s on is when we press the max defrost button to clear the windscreen while driving. The AC definitely works though it’s just not on for long when we use it. I’ll try warm it all up and see if that helps solve it. ![]() Had a look at the door seals etc and everything seems like normal. Cheers |
Yeah AC is working fine for the brief time we’ve used it. |
That’s probably your your problem, the AC dries the air.
Oh wow didn’t know that about running it permanently, learn something new everyday!
