Home > Technical (L322) > Bushings and Arms
DeeJay
South Africa 2011 Range Rover Vogue SE TDV8 Fuji White
Bushings and Arms
There is a rattle / clanging over really bumpy roads that Im trying to get the source of on my L322.
I've inspected all the bushings as best I can, and Id say the bushings in the front lower control arms look like they need replacing. Id also say replacing the lower control arms are the current best bet at eliminating the noise.
What is the general view on quality of bushings and arms available on eBay and Amazon in comparison to dealer parts? What should I be looking out for before committing to the purchase?
...in South Africa, so returning something that doesn't look right only when it gets here is not ideal if I want the car ready for summer holiday.
Ofcourse, as I'd be making my way through replacing all the bushings in the future, the question around quality and how to choose the right ones applies as well, so this is not necessarily only a front lower control arms question. 2011 Vogue SE 4.4 TDV8
Post #609662 18th Oct 2021 9:33pm
Fox889
I always worry about ebay suspension stuff unless it's a known make and/or supplier. If you can guarantee the quality off the "net" then fair enough.
I believe there's a lot of chinese copies out there that really aren't fit for purpose.
You could ask Advanced Factors on here if they ship to SA, at least using these guys it's good stuff.
Tricky one for you. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #609677 19th Oct 2021 7:24am
DrRob
Advanced Factors Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #609679 19th Oct 2021 7:43am
Depends how long you plan on keeping it....
If you only want to do the job once then fit genuine, anything else will not last long...
I changed the bushes in the old arms once, had full workshop facilities including a 30ton press...
I won't be doing it again, the hassle is not worth the saving IMHO...
Have you checked the drop links, they are the usual culprit for front end clonks... Thumbs Up Pete
Post #609684 19th Oct 2021 8:40am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
With age etc if I was keeping it I would f#£k bushes off and change arms with new bushes, used Delphi in the past with good success. Lemforder also decent. I recently changed the upper and lower rear hub bushes using a dedicated bush removal kit.
If my appointment tomorrow says it’s a cyst or similar, and not testicular cancer I will have to do subframe bushes at some point this year too.
I know those are rough, but great write ups here are a missive help! Formerly happymadison1978
Post #609943 20th Oct 2021 11:18pm
Snowy90 L322
United Kingdom 2004 Range Rover HSE Td6 Giverny Green
As said before, if your keeping it avoid unbrand stuff, these cars are brutal on bushes and will chew threw anything other than OEM apart from i guess polybush etc..
Post #609955 21st Oct 2021 8:17am
DeeJay
I suppose that a special car deserves special care, this one is still special - Im not quite sure its reached a point in its life where i can afford to fit a part that will do the job for one trip once a year. This is a working car. So thank you for pointing it out along with other responders, and will have to pay special attention to ensure I source quality parts. 2011 Vogue SE 4.4 TDV8
Post #609971 21st Oct 2021 10:14am
