Home > Technical (L322) > Rover All Comms - First Look
Page 4 of 7 <1234567>
i got a pre-production unit ..they are on sale from the 25th rob. ... - .- -.
Post #59389 8th Apr 2011 11:53am
InVogue
Another idea/request - enabling of "triple-flash" indicator function Thumbs Up
Post #59429 8th Apr 2011 2:51pm
jonminns
United Kingdom 2008 Range Rover Vogue TDV8 Santorini Black
+1 on the 3 flash 'lazy' indicators, that'd be great!
Post #59556 9th Apr 2011 2:21pm
i'm hoping that the developer of this programme is following this thread and is taking these suggestions on board..
fyi, i've managed to do the following so far with mine,
adjust volume on reverse bleeper
switch off reverse bleeper
disable steering column movement
switch on dip beam as a drl
..and reset various faults ... - .- -.
Post #59557 9th Apr 2011 2:28pm
dan_uk_1984
Confused - what is this tripple flash you speak of?
Post #59558 9th Apr 2011 2:41pm
i think its when you are travelling down the motorway and you want to overtake, you flick the indicator up/down and the indicators flash three times... ... - .- -.
Post #59563 9th Apr 2011 3:15pm
dan_uk_1984
Is that an option on the RR?
RAC will only enable an option if it exists already...
Post #59566 9th Apr 2011 3:20pm
dont know mate, i dont indicate anyway so no big deal for me.. Very Happy ... - .- -.
Post #59569 9th Apr 2011 3:28pm
andylouca
2003 Range Rover HSE Td6 Java Black
Do you know if this will help to unlock the passenger door which has now been stuck for weeks......
I have already emailed Storey for a possible delivery date and am waiting to order. Do you think we could get a group discount for a bulk order?
Post #60949 19th Apr 2011 2:49pm
dont think so..it sounds like the 'mechanics' of the door are faulty.. ... - .- -.
Post #60950 19th Apr 2011 2:53pm
andylouca
cheers scarey, I only asked because when I rang up one of the dealers to get new latches they said it may well not be the latch but would be worth checking out first. All the cables etc are working as they should be (if you remove the trim form the window you can see into the door) I can see the latch being operated but the door will not open. My only hope is I can operate the lock/unlock function via diagnostics or at least prove it is the latch before smashing it.
I cant wait to get my hands on a RAC system.......
Post #60957 19th Apr 2011 3:47pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
Triple flash of the indicators has been on RRS/D4/FFRR since about 2008/9 - have had it on both my RRS's and it's on my current 2010. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #60959 19th Apr 2011 4:04pm
defo sounds like the mechanical side andy, something isnt engaging properly to open the door...
the RAC is a clever bit of stuff although some of it is still in development, i keep hoping to get faults come up so i can clear them ..one change i have done is to switch off the steering column so it doesn't move when you turn the ignition on, bound to save wear on the motors... ... - .- -.
Post #60970 19th Apr 2011 5:11pm
its encouraging that its on a later model ,hopefully it can be activated on the 2002/2005 models.. ... - .- -.
Post #60971 19th Apr 2011 5:14pm
My steering column doesn't move when i put the ignition on or off ..... yet it does work as it is programmed into the drivers seat memory if SWMBO has driven it ...
Post #60973 19th Apr 2011 5:22pm
