Home > Maintenance & Mods (L322) > 2011 4.4 TDV8 - Brake Pad Recommendations |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
not sure about rotors but I highly recommend EBC pads. I went for EBC Green
16th Oct 2021 6:20pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3249 |
Technicaly all disks should be the same as they used the same grey iron. Also all pads for road use from major manufacturers should be the same in terms of stopping power as they have to have the same friction coefficient. Differences may be present in dust, wear rate, fade resistance etc. I’m not that impressed by the brake ‘feel’ of mine and was considering replacing disks and pads but doing some reading it seems to be normal so as the pads are OE I’ll have to get used to it. 2012 TDV8 Vogue (L322) |
16th Oct 2021 7:21pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3165 |
I had "genuine" LR disks and pads fitted at great expense and they are the squeakiest, nosiest, worst I have ever had in 14 yrs!!
17th Oct 2021 3:53pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4306 |
I phoned site sponsor Advanced Factors and Paul Redding threw a kit in the post. Non genuine but happy and no squeaks or anything and stop just fine!
17th Oct 2021 4:16pm |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 451 |
Just fitted Brembo discs and pads.
17th Oct 2021 6:09pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8603 |
OE pads for the 4.4 are Jurid, I know because I bought a boxed set from LR and they were stamped, I also had a set of Jurid pads later and they were the same…. if you can find them the work well if properly fitted….(AUTODOC has them at the moment)
18th Oct 2021 7:18am |
procee Member Since: 05 Oct 2016 Location: Grampian Posts: 28 |
EBC yellow pads for me, too many hills and twisty roads round about me for the stock pads not to fade. 2006 MY FFRR 4.2 S/C autobiography (Auckland Blue - 901)
20th Oct 2021 9:06am |
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 |
I had genuine (not e-bay) Brembo's fitted front and rear and I have to say I am disappointed in them. I was going to go EBC but it was in for service and they rang saying needed changing so might as well do whilst it was up on ramps etc so ended up with Brembo.
21st Oct 2021 8:35am |
Mike220 Member Since: 21 Sep 2020 Location: uk Posts: 116 |
Really happy with the ferodo I fitted on mine, don't forget that most are only as good as the fitting procedure - cleaned, fitted, greased (with the correct substances of course), and then the correct bedding in and heat cycle procedure. If they're not bedded properly and heat cycled effectively at the start even the best pads can feel awful during their life time 2011 Vogue SE Tdv8 FFRR |
21st Oct 2021 12:38pm |
Also don't forget a brake fluid flush and flexi hose replacement as both these items are essential to the feel of the brakes - i.e any dirt/water in the fluid or softness in the flexible hoses means mechanical force being lost and not getting to the pistons. 2012 TDV8 Vogue (L322) |
21st Oct 2021 2:10pm |
JW911 Member Since: 09 Dec 2008 Location: Hampshire, UK Posts: 235 |
Going from my 3.6TDV8 with Brembos to my 4.4 with LR brakes, I miss the Brembos as the LRs do start to fade if they’re being “used”. Half tempted to get them fitted as the car is a keeper. Who’s the cheapest supplier? 2012 4.4 TDV8 Westminster
21st Oct 2021 6:38pm |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2574 |
The 4.4 TDV8 has Brembo calipers, just bigger ones (and discs) than the 3.6 had (pre-facelift) - 6 piston/380mm vs 4 piston/360mm. |
21st Oct 2021 7:17pm |
