Home > Maintenance & Mods (L322) > 2011 4.4 TDV8 - Brake Pad Recommendations
Mike Edwards
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
I've done a search and it seems that OEM discs are reasonably priced and worth purchasing but I can't find any consensus on which brake pads to use with them. The OEM pads seem to be horribly overpriced so wondered what people would recommend? Thanks.
Post #609400 16th Oct 2021 5:15pm
GGDR
not sure about rotors but I highly recommend EBC pads. I went for EBC Green
. Cheers, Greg
Post #609406 16th Oct 2021 6:20pm
JayGee
Technicaly all disks should be the same as they used the same grey iron. Also all pads for road use from major manufacturers should be the same in terms of stopping power as they have to have the same friction coefficient. Differences may be present in dust, wear rate, fade resistance etc. I’m not that impressed by the brake ‘feel’ of mine and was considering replacing disks and pads but doing some reading it seems to be normal so as the pads are OE I’ll have to get used to it. 2012 TDV8 Vogue (L322)
Post #609415 16th Oct 2021 7:21pm
Dolphinboy
I had "genuine" LR disks and pads fitted at great expense and they are the squeakiest, nosiest, worst I have ever had in 14 yrs!!
AVOID!!
go for EBC Green I would suggest.
Post #609503 17th Oct 2021 3:53pm
DrRob
I phoned site sponsor Advanced Factors and Paul Redding threw a kit in the post. Non genuine but happy and no squeaks or anything and stop just fine!
https://www.advancedfactors.co.uk/brake-parts-51-c.asp Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #609504 17th Oct 2021 4:16pm
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Just fitted Brembo discs and pads.
Not sure of their longevity yet. Hoping they’re ok as they’re a decent brand. Christian.
Current Cars
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #609518 17th Oct 2021 6:09pm
OE pads for the 4.4 are Jurid, I know because I bought a boxed set from LR and they were stamped, I also had a set of Jurid pads later and they were the same…. if you can find them the work well if properly fitted….(AUTODOC has them at the moment)
Personally I always fit LR discs, I’ve tried others and they’ve been variable, sometimes ok but I have had a set of aftermarket ones warp, but the gen ones are always a good bet. There is nothing that can't be fixed with a hammer😜😜
Post #609548 18th Oct 2021 7:18am
procee
EBC yellow pads for me, too many hills and twisty roads round about me for the stock pads not to fade. 2006 MY FFRR 4.2 S/C autobiography (Auckland Blue - 901)
1996 Discovery 300Tdi S (death by rusting) (Silver)
1995 Volvo 850 T-5 est (now in Valhalla) (verdigris metallic)
1987 Volvo 240 GL est (now in Valhalla - not owned but driven lots)
1990 Kawasaki ZZR600 Blue
1979 Honda CB250 NA Superdream Red
Post #609777 20th Oct 2021 9:06am
mm289
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Ipanema Sand
I had genuine (not e-bay) Brembo's fitted front and rear and I have to say I am disappointed in them. I was going to go EBC but it was in for service and they rang saying needed changing so might as well do whilst it was up on ramps etc so ended up with Brembo.
They feel really "harsh" on prolonged braking e.g. coming of a motorway slip and squeeked like mad. Since fitting I have stripped the front down myself and cleaned and refitted with ceramic grease on the back of the pads which has stopped the squeeking but the feel still isn't as good as I would like.
Just my experience Smile
MM 2011 TDV8 AB
2006 TD6 AB (Gone to Wales)
Post #609959 21st Oct 2021 8:35am
Mike220
Really happy with the ferodo I fitted on mine, don't forget that most are only as good as the fitting procedure - cleaned, fitted, greased (with the correct substances of course), and then the correct bedding in and heat cycle procedure. If they're not bedded properly and heat cycled effectively at the start even the best pads can feel awful during their life time 2011 Vogue SE Tdv8 FFRR
Post #609982 21st Oct 2021 12:38pm
JayGee
Also don't forget a brake fluid flush and flexi hose replacement as both these items are essential to the feel of the brakes - i.e any dirt/water in the fluid or softness in the flexible hoses means mechanical force being lost and not getting to the pistons. 2012 TDV8 Vogue (L322)
Post #609994 21st Oct 2021 2:10pm
JW911
Going from my 3.6TDV8 with Brembos to my 4.4 with LR brakes, I miss the Brembos as the LRs do start to fade if they’re being “used”. Half tempted to get them fitted as the car is a keeper. Who’s the cheapest supplier? 2021 3.0 P400 Vogue
2012 4.4 TDV8 Westminster - gone!
2007 3.6 TDV8 Vogue - gone!
2003 4.4 V8 HSE (LPG) - gone!
2018 F-Pace 25t Portfolio
1974 LR Series III Lightweight FFR
2014 BMW 640i Gran Coupe
Post #610017 21st Oct 2021 6:38pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
The 4.4 TDV8 has Brembo calipers, just bigger ones (and discs) than the 3.6 had (pre-facelift) - 6 piston/380mm vs 4 piston/360mm.
Post #610023 21st Oct 2021 7:17pm
