![]() | Home > Wheels & Tyres > Overly large tyres on 22inch rims |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7894 ![]() ![]() ![]() |
For the time it takes, I’d try it without the spacers… though of course the tyres might rub on the inside, but you can always put the spacers back and be no worse off. I’m assuming the spacers have been added for aesthetics, I don’t know the max tyre size that fits under.
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3780 ![]() ![]() |
Why not just put it in extended mode going over speed humps 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
Dave G Member Since: 30 Jul 2020 Location: Dorset Posts: 84 ![]() ![]() ![]() |
Maybe narrower spacers will solve the problem? 2013 Range Rover Autobiography 4.4 SDV8
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8509 ![]() ![]() ![]() |
That's a 32" tyre, I had those on fatty off roader, I didn't have spacers but don't know what offset your wheels are, as has been said you will probably get away with a smaller spacer or none at all... the only issue I had was rear off side arch where the fuel filler pipe goes to the tank, had to heat up the arch and persuade it in an inch or so...
Bronjen Member Since: 13 May 2018 Location: DE2 Posts: 44 ![]() ![]() ![]() |
285/ 45 / 22 are too tall the speedo will not be accurate unless you use an IID tool to recalibrate the speedo, |
DBB Member Since: 18 Mar 2016 Location: United States Posts: 42 ![]() ![]() |
If those are authentic overfinch wheels, 22x9.5 ET50, then they should clear without the spacers. |
