Home > Technical (L322) > Heater not heating at all!! |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1345 |
Airlock in the system I reckon...
16th Oct 2021 2:44pm |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 |
It s 3.6 tdv8. Wow is it so hard? They said slight air in the system does that. 2010 3.6tdv8 180k km. sold 06 td6 160k Sold 03 td6 260k |
16th Oct 2021 3:52pm |
The tdv8 3.6
16th Oct 2021 4:44pm |
That's 4.2 drawing but I think fbh side is same.
17th Oct 2021 4:33am |
Is it normal it's blurping each time I open air valve on water tank after I turn off the engine? 2010 3.6tdv8 180k km.
17th Oct 2021 9:11am |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
Did you check the auxiliary coolant pump, that's fitted on the bracket directly underneath the double solenoid valve. If that's not working properly it could be affecting the heating.
17th Oct 2021 9:17am |
And the fbh valve is cold no heat at all..
17th Oct 2021 9:41am |
I have seen the pump but did not check. It says for its for coolant turnover when stationary or when engine is turned off. Owners say for 4.2 engines even adding water must be done slowly for not to have air I don't know if 3.6 is so sensitive too. The fbh valve and all hoses are cold under Polen filter cover. Valve or radiator? we will see. And this is left side facing the car. 2010 3.6tdv8 180k km. sold 06 td6 160k Sold 03 td6 260k |
17th Oct 2021 10:14am |
The radiator is fine.
17th Oct 2021 12:50pm |
https://www.fullfatrr.com/forum/post495181.html
17th Oct 2021 2:17pm |
Yes, that is the valve I originally referred to, it's called the changeover valve. It has a single solenoid as opposed to the other valve which has two solenoids. The 3.6 engined FF must have that valve located in a different position to the 4.4 engined FF. I have just got my FF back from the mechanics and he wasn't able to replace the internals in this valve, it has a different plunger and washers inside, so the repair kit I gave him wasn't correct. To get a genuine replacement valve is damned expensive, it is possible to bypass this valve with a plastic hose tee piece to connect all three hoses together. The valve is normally open, so won't affect the cooling system if it's bypassed.
18th Oct 2021 12:34pm |
Yes it is much easier to check changeover valve on 3.6 if the hoses are hot or not.
18th Oct 2021 4:58pm |
If you connect the three hoses directly with one of those two tees, you should still be able to get cold air as it is the double solenoid valve that controls the flow of coolant to the two heater matrixes.
18th Oct 2021 7:20pm |
But the valve operates when we give direct current from battery.
19th Oct 2021 12:50am |
