Home > Technical (L322) > Rear door water ingress
DaleL322
United Kingdom 2009 Range Rover Vogue SE TDV8 Stornoway Grey
I have just been to the car after it’s been stood a while and when I opened the rear door a load of water came rushing out
I’ve never had a problem before but it’s soaked the carpet too which is upsetting
I’ve visually checked the door drains at the bottom and they appear to be clear
Anyone ever had this happen to them before?
Cheers guys
Dale 2010 MY Range Rover 3.6 TDV8 Vogue SE - Stornoway Grey with Semi-Aniline Ivory Leather and Piano Black Trim
https://www.fullfatrr.com/forum/topic58777.html
Post #609375 16th Oct 2021 1:02pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Have the same, unsure where it is being retained though. Let us know if you find the reason.
Post #609378 16th Oct 2021 1:18pm
FJ12Jagmen
United Kingdom 2007 Range Rover Vogue TDV8 Santorini Black
Same on mine but the water seems to get trapped between seals. It doesn't get in the car. I've had the offside rear door card off and can't find any issues. Drain holes are free. The bottom of the door must be so close to the sill that it seals the water in. Bit of a mystery.
Post #609381 16th Oct 2021 1:43pm
the door needs 'bending' using a bit of 2x4 wood...there's a thread re this on the forum somewhere.. ... - .- -.
Post #609382 16th Oct 2021 2:00pm
FJ12Jagmen
Found it titled "This shouldn't happen". Suggests using a piece of wood to prevent the bottom of the door closing whilst pushing inward at the top.
Think I'll live with it, don't fancy that idea knowing my luck I would end up moving the hinges and creating a world of hurt.
Post #609383 16th Oct 2021 2:19pm
DaleL322
Could you possibly share the link please, as I can't seem to find it.. Sad 2010 MY Range Rover 3.6 TDV8 Vogue SE - Stornoway Grey with Semi-Aniline Ivory Leather and Piano Black Trim
Post #609554 18th Oct 2021 8:05am
FJ12Jagmen
Not easy to find again but here it is -
https://www.fullfatrr.com/forum/topic12101-15.html
Post #609582 18th Oct 2021 10:49am
I wouldn't worry about causing any problems, the doors and hinges are remarkably strong. If anything you will be lucky to bend the door at all. Smile
Post #609586 18th Oct 2021 11:32am
stuart_2006
Try this: get a ~1/2" length of black cable a couple of millimetres diameter (something like a bit of old headphone cable). Using a small amount of glue, glue it vertically across the bottom of door seal to hold a small section of seal away from the body to allow water to drain. Unobtrusive, and if it doesn't work then you can carefully peel it off.
Post #609588 18th Oct 2021 11:42am
DaleL322
Thanks for the information guys, I will try these techniques for sure... now to dry the carpet out Rolling Eyes Censored 2010 MY Range Rover 3.6 TDV8 Vogue SE - Stornoway Grey with Semi-Aniline Ivory Leather and Piano Black Trim
Post #609692 19th Oct 2021 10:43am
DaleL322
I see you were one to offer advice on the original post Very Happy
There are no pictures.. is it obvious where on the door you place the wood? Bow down 2010 MY Range Rover 3.6 TDV8 Vogue SE - Stornoway Grey with Semi-Aniline Ivory Leather and Piano Black Trim
Post #609694 19th Oct 2021 10:55am
Just place the wood as far back as you can on the bottom of the door Thumbs Up
Mine still doesn't leak after 9 years.
Post #609732 19th Oct 2021 5:05pm
