Home > Technical (L322) > Rear door water ingress |
DaleL322 Member Since: 04 Mar 2021 Location: Stamford Posts: 176 |
I have just been to the car after it’s been stood a while and when I opened the rear door a load of water came rushing out
16th Oct 2021 1:02pm |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
Have the same, unsure where it is being retained though. Let us know if you find the reason. |
16th Oct 2021 1:18pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35281 |
the door needs 'bending' using a bit of 2x4 wood...there's a thread re this on the forum somewhere.. ... - .- -.
16th Oct 2021 2:00pm |
FJ12Jagmen Member Since: 25 Jun 2020 Location: Danbury Essex Posts: 59 |
Found it titled "This shouldn't happen". Suggests using a piece of wood to prevent the bottom of the door closing whilst pushing inward at the top.
16th Oct 2021 2:19pm |
Could you possibly share the link please, as I can't seem to find it.. 2010 MY Range Rover 3.6 TDV8 Vogue SE - Stornoway Grey with Semi-Aniline Ivory Leather and Piano Black Trim
18th Oct 2021 8:05am |
Not easy to find again but here it is -
18th Oct 2021 10:49am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
I wouldn't worry about causing any problems, the doors and hinges are remarkably strong. If anything you will be lucky to bend the door at all. |
18th Oct 2021 11:32am |
stuart_2006 Member Since: 17 Jul 2018 Location: Holsworthy, Devon Posts: 125 |
Try this: get a ~1/2" length of black cable a couple of millimetres diameter (something like a bit of old headphone cable). Using a small amount of glue, glue it vertically across the bottom of door seal to hold a small section of seal away from the body to allow water to drain. Unobtrusive, and if it doesn't work then you can carefully peel it off. |
18th Oct 2021 11:42am |
Thanks for the information guys, I will try these techniques for sure... now to dry the carpet out 2010 MY Range Rover 3.6 TDV8 Vogue SE - Stornoway Grey with Semi-Aniline Ivory Leather and Piano Black Trim
19th Oct 2021 10:43am |
I see you were one to offer advice on the original post There are no pictures.. is it obvious where on the door you place the wood? 2010 MY Range Rover 3.6 TDV8 Vogue SE - Stornoway Grey with Semi-Aniline Ivory Leather and Piano Black Trim https://www.fullfatrr.com/forum/topic58777.html |
19th Oct 2021 10:55am |
Just place the wood as far back as you can on the bottom of the door
19th Oct 2021 5:05pm |
