Home > Maintenance & Mods (L405) > Changing wiper blades
Page 5 of 5 <12345
Landphil
I have read this thread and all the others on changing wiper blades but I’’m struggling to get the rear wiper off. It’s the hook fitting but no lugs to press or tabs to pull. It has a rivet for the hinge and two slightly bigger holes forward of the hinge but no obvious tab to push in. After squirting a very small amount of penetrating oil into the fitting the wiper body is moving within the hook but will not slide out.
Advice would be appreciated.
Post #608165 4th Oct 2021 10:11am
I usually get mine to a vertical position by opening the boot slightly mid cycle - then just push the wiper upwards and it pops out
Post #608167 4th Oct 2021 10:29am
Landphil
I tried that and nothing moved except the wiper arm bent to an alarming shape, but recovered.
Just did it again after your advice and with the bit of lubrication it gave way and it’s off.
Thank you Alistair, you gave me the confidence to push a bit harder.
Post #608168 4th Oct 2021 10:44am
Here's my old one.
You can see the tabs on the left end. They need to be squeezed together to release the blade.
They're not that strong so just pushing as Alastair says would probably work. I actually found it more fiddly to get the new one in place as the tabs aren't strong enough to spring out until perfectly aligned. Mike - MPx
Post #608169 4th Oct 2021 10:45am
Landphil
Thanks Mike for your reply but that fitting is completely different to mine.
Post #608173 4th Oct 2021 11:27am
Pendle
United Kingdom 2016 Range Rover SVAutobiography SDV8 Firenze Red
Rear Wiper service mode
Check tis Powerfuluk video out!
see from 1 min 50 seconds for the service mode procedure!
Mike L405 SV Autobiography 2016
XJS V12 Convertible 1990
Previous:
L322 Vogue SE 2011
Mazda MX5 1999
Saab 9-5 2.0 SE 2000
Discovery 3 door 300 Tdi 1995
Fiat X1/9 1983
Citroen BX 1.9 GTI Turbo 1987
Austin Princess Vanden Plas 1972
Several too embarrassing to publish and a bunch of Company cars incl RAV4 Honda Accord Coupe and a Bora.
Post #657203 20th Feb 2023 10:55am
hmallett
United Kingdom 2013 Range Rover Autobiography SDV8 Firenze Red
I appreciate that this is an old thread, but I found it while doing some research.
I see that people have commented that some have a 24" wiper and a 20" wiper, and some have two 24" wipers.
The Land Rover parts website shows that the part numbers for the driver's side have changed several times, and the driver's side and passenger's side had different part numbers. Then there's a final change and both sides use the same part number.
So maybe LR initially used different size wiper blades for each side, then changed their mind (maybe to simplify inventory?), and settled on the same size both sides. While suppliers such as Bosch kept the 20"/24" sizes on their configurator.
Post #711778 13th Feb 2025 9:24pm
Page 5 of 5 <12345
