Home > Technical (L405) > Harsh gear shift sdv8 autobox |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1365 |
Mine needed a gear change software update due to occasional thumping on firmer acceleration. The problem seemed to be that the gear wasn't going in soon enough, and when it did come in the revs were that much higher and it thumped through the driveline, occasionally with quite a bang. Apparently it was a known issue and LR had issued instructions to dealers about it with a software update. In my case it was done under warranty.
1st Oct 2021 11:43am |
fenair Member Since: 01 Sep 2021 Location: Norfolk Posts: 47 |
Ok Cheers, i have the service print out and its all up to date with all campaigns, it may well be my driving style, i have a Disco 4 Commercial as my daily work truck, same box, but you seem to be able to give it some beans out of a roundabout and if you catch the car in front you can ease back a touch on the throttle and then apply a bit more gas and accelerate and it will then change up, I'm wondering if i am feathering the throttle and with this one it see's the throttle angle reducing so instantly cogs up as its got the torque where the V6 kind of is happy with the revs on.. something for me to monitor. SDV8 2015 |
2nd Oct 2021 2:03pm |
OK, but for the avoidance of doubt the gearbox software fix I had is not a routine service item, it was just for cars that had exhibited the "shunt on kickdown" issue I had, yours may of course be different, as you say you can monitor it. Only Range Rovers since 1988 |
2nd Oct 2021 7:36pm |
Ok thanks for that, it's going in to the main dealer on Tuesday for the rear diff seal to be replaced, I will ask then.
2nd Oct 2021 8:07pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1182 |
Watching with interest because my 322 does the same. |
13th Oct 2021 9:19am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8064 |
It is nothing to do with your driving style, however you drive the gearbox should sort it out and behave well.... Pete
13th Oct 2021 11:19am |
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 230 |
My scv8 does this too. Hard acceleration, loud bang upon downshift. Feels/sounds like it is under the drivers floorboard. Could be the transfer case. Others have said a fluid exchange may help. Dan. 🇨🇦 2013 L405 5.0 SCV8 |
13th Oct 2021 3:26pm |
As above, see whether it needs the gear change software update, my symptoms were exactly the same as Bora20's. Only Range Rovers since 1988 |
13th Oct 2021 8:17pm |
Update
14th Oct 2021 7:36am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35094 |
Pat, was that under warranty or a cost to you.. ... - .- -.
14th Oct 2021 8:30am |
That was a cost to me, car is 2015 SDV8 2015 |
14th Oct 2021 8:51am |
Hi Pat. When it does change in the lower gears, is it nice and smooth now? 2500rpm sounds a bit high to me on a gentle throttle. |
14th Oct 2021 8:52am |
Smooth as silk, undetectable other than the rev needle drops, 2500 is a slight overstatement, but around 2200 , it needs a changes just the same as my disco 4, which is 6 months older, so obviously a fuel map issue with the V8 be v6 I suspect, it never seemed like it was cutting the injector's on the upshifts, it was ok if you pinned the throttle but that's because it had gone through the torque band, 1500-1800 was bang on for the most pulling power. Very pleased with it now, so shows things be done if you have a dealership or indi who wants to help.. That said it's not cheap... But shouldn't have a rr if you can't afford the dealership rate, probably why it never got done... I suppose it's one of those things if lr don't think it's a issue it won't go in the update, the just use the phrase, " if the owner experiences" SDV8 2015 |
14th Oct 2021 4:00pm |
14th Oct 2021 4:46pm |
