Home > Maintenance & Mods (L322) > IID Tool not doing what's expected
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
So I have changed my lower suspension arms and now the car is showing active suspension faults.
Tried to calibrate using IID and it simply does not work. The car doesn't go up or down when using either guided or manual calibration. It doesn't move at all. It seems that if I hold the iPad in landscape mode the suspension calibration mode doesn't do anything at all, I just get a blank screen.
Tried using both guided and manual on both a iPhone and an iPad but same result, then I got an error message and the car is stuck in "Suspension not in customer mode"
I have sent logs to GAP but I must say for £475 I am very disappointed that this tool isn't flawless.
I have used loads of specialist OBD tools before, for example VAG-COM and never seen this type of behaviour. It feels like the software is in beta.
Anyone else had any issues like this?
Post #607866 1st Oct 2021 2:20pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
I don't think it's a problem with the tool - the suspension needs to be in normal mode to calibrate.
Take a look at the post by dgardel in this thread 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #607869 1st Oct 2021 3:05pm
Caesium
When entering calibration mode on the tool the message not in customer mode appears.
It wasn’t there before. The tool switches that message on.
Post #607871 1st Oct 2021 3:11pm
MikeO
Well it's your call but I would try toggling the build mode as I suggested and see whether it's set correctly. I had all sorts of weirdness on my D3 when the build mode was set incorrectly. 2016 Skoda Octavia VRS Estate
Post #607878 1st Oct 2021 3:38pm
cass
Check it’s not in tight tolerance mode as well
Post #607881 1st Oct 2021 3:55pm
Caesium
This tool is starting to get on my nerves now.
I opened up the compressor to make sure it was working ok, and removed the cleaned the filter which is now nice and clean.
I start the car, make sure it's in normal drive height and wait until the compressor stops running, then enter calibration mode and guided calibration.
As soon as I enter the calibration mode the car starts going mad and venting the nearside front all the way down to it's bump stop!
WTF is it playing at?!
Post #607890 1st Oct 2021 5:44pm
Caesium
Video of the oddness
Post #607891 1st Oct 2021 6:20pm
Gsxr1250dave
You have accidently reversed a height sensor or both a common mistake when you disconnected then to change the lower arms.
You should not need to recalibrate after changing lower arms
Post #607896 1st Oct 2021 8:58pm
Caesium
I thought that but drivers side adjustment arm can only go one way. Passenger’s side is a mirror of the driver side.
The manual states the suspension needs calibrating. When I started the car back up after the work was complete I got a suspension system failure warning.
Steering wheel is also not straight following the change, which is a little odd.
Post #607897 1st Oct 2021 9:02pm
Gsxr1250dave
Take a photo of you height sensor and I will compare it to mine
Post #607904 1st Oct 2021 10:36pm
Range Rover L322
You would be better talking directly to Pat at Gap. He is the Chief Engineer and excellent, he just solves problems.
gapteam@gap-diagnostic.com
The IIDTool is excellent but imperfect. It covers so much ground really well but.... how to say this!!.... Range Rovers are not an exact science so the solutions are not always binary.
hope that helps !
Post #607905 1st Oct 2021 11:19pm
kevinp
I would have thought that if your old arm bushes were really worn the new ones have pulled the hub into it's correct position which will have altered the tracking making your steering wheel not straight.
Post #607907 2nd Oct 2021 12:08am
Caesium
Managed to get the suspension calibrated this morning, from cold- Result.
I've already got Pat @ GAP on the case as there's certainly some odd behaviour but cannot pin down if it's iOS related or my car at the moment.
I thought I'd pre-empt a GAP diagnosis and ask here in case anyone had a fix or seen such issues.
Post #607917 2nd Oct 2021 9:20am
