![]() | Home > Maintenance & Mods (L405) > Cack ride quality |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 771 ![]() ![]() ![]() |
Your Dynamic Response (hydraulic anti-roll bar) fluid is on the nearside, just behind the airbox on that side. Have you checked your fluid levels? It could be worth doing a quick check to make sure you're not critically low on anything.
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2665 ![]() ![]() |
Ah that makes sense, clearly something is leaking , I’ll have a gander tomorrow. Just wasn’t sure if it was my imagination, is the fluid MD only ? |
Not at all. It's Texaco Cold Climate Power Steering Fluid.
Excellent , looks like I’ll need some tomorrow, see if euros or halfords have any , cheers . |
Got some fluid from local MD, went to fill up, how the hell are you meant to see the level when you can’t see the fluid through the tank? Cue me filling it up to the brim then having to sook some out with a calpol syringe ffs. Drives great though |
Just been to the garage, leak is from one of the rear dampers, didn’t even cross my mind that if the car is front end in or reversed in the drive it’s the opposite side to the fluid reservoir, silly mistake. Also found another leak from as close as we can see offside front wheel well area, quite wet , looks to have been leaking for a while. Side step is covered fight at the front, looks like there may be a cooler in that region? |
There are a few things over that side:
Double-check the shocker is leaking as most 405's & 322's show damp areas on the rear shockers... That said I have had a couple of 322's have 100% rear shocker failure but they are very obvious... |
Cheers Craig, I was underneath when it was on the ramp, rear shock was soaking wet |
