![]() | Home > Technical (L322) > 5.0 S/C L322 Fuel pressure problems P0087-00 fault code |
WB Member Since: 26 May 2016 Location: London Posts: 303 ![]() ![]() ![]() |
Good to know - thanks Pete |
woodrjh Member Since: 13 Sep 2021 Location: Burgess Hill Posts: 26 ![]() ![]() ![]() |
Just acquired a 2011 (2012MY) L322 Autobiography 5.0 SC with 81K miles.
Congrats on the 5.0.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8311 ![]() ![]() ![]() |
The fault is low, high pressure fuel, nothing to do with the low pressure side...
The service history is not full LR, and I have most of the bills for the last few years. No sign of the chains being done, but no major rattles even with the engine cover off. Sounds like there may be the supercharger knock, so I’ll do that if the chains start rattling. No nasty codes in SDD, I have an IID tool on order, so I’ll check the pressures once it’s here.
Locking rear diff is standard on an Autobiography... |
That would be nice, but I looked in the options list for the 11.5 model year April 2011 which is in the WIKI, and on that list it's an option for all the cars. It can only be fitted with adaptive dynamics which was standard on all the cars at that time and is on my car.
Play with the terrain knob and the display should come up with a padlock over the rear axle on some settings.. as well as a padlock over the centre diff.. |
My terrain control display shows the rear diff padlock in green and unlocked when in one of the terrain modes.
Weird... they are very good without one though... |
chdavis Member Since: 28 Nov 2021 Location: Washington DC Posts: 44 ![]() ![]() |
Thanks for this thread! Have the exact same issue and I bet you saved me a lot of dicking around 2012 Range Rover HSE | 2011 Range Rover Autobiography | 2010 Range Rover Sport Supercharged
Just had my two HPFPs replaced. This thread was invaluable. Thanks again for posting. 2012 Range Rover HSE | 2011 Range Rover Autobiography | 2010 Range Rover Sport Supercharged
