![]() | Home > Technical (L322) > 5.0 S/C L322 Fuel pressure problems P0087-00 fault code |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8555 ![]() ![]() ![]() |
After a few seconds of running at full throttle I get a "restricted performance" amber warning, this clears by pressing OK on the steering wheel and clears completely after a few seconds. I thought this maybe due to poor quality petrol so have run two tanks of Shell super+ through it but it is still doing the same... don't get me wrong it's no great issue as there aren't too many opportunities to run at full throttle... at part throttle everything is OK...
I've ordered one, it's on the way, I don't fit pattern parts to mine.. |
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 ![]() ![]() ![]() |
Not had any problems with my SC under full throttle. But if you would like happy to repeat your test on mine and measure same sensors and see if this is normal graph or not, as you maybe looking in the wrong place and it could be a bad injector. |
Thanks for the offer, it's definitely a low fuel pressure problem, as is usual with these things, easy to fix once you have found out what to fix...
WB Member Since: 26 May 2016 Location: London Posts: 303 ![]() ![]() ![]() |
Worth running a can of BG44k through it - it's the only type LR recommend and useful for cleaning the injectors anyway.
For anyone else with this fault....
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
Good effort mate.
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
You would want one. It’s a brilliant engine, and very well matched to this car. It’s powerful, it’s fast, it sounds amazing under load. And it’s the cleanest environmentally friendly of them all which I still find hilarious and my mate Greta love it 😂
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1368 ![]() ![]() |
I don't want one, I'll stick with the 4.2 for the time being |
It is a wonderful thing to own and drive, stunningly sumptuous and a lovely place to be... |
Well done mate and thanks for the write up! Glad to see more infio going in to the 5.0 knowledge base. Out of interest do you know what it is that goes on the fuel pumps? Is it seals? Whats the mileage on yours? |
You couldn't see any difference in new to old, I presume they have some sort of diaphragm inside, there are places selling refurbished ones...
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16341 ![]() ![]() ![]() |
The same basic gearbox is used in the Aston Martin DB9 and we recently Tuned the gearbox using a plug in OBD2 tuning dongle from JF Automotive... This speeds up changes, lowers the lock up speed, resets the adaptions etc etc etc Turned a lackluster gearbox into a perfectly acceptable one IMHO and all for £399 |
Having now driven Wifey's 5.0 a few times, I'm very impressed by just how dialled down the engine feels in normal use... You really do have to provoke it to drive like a hooligan which wifey is very happy with... IE she drives like Terry Wogan whilst doing his lap on TG... Very sedate usually, she's scared of driving my fast cars! |
