Home > Maintenance & Mods (L322) > Rust prevention strategies?
Zerosumgame
I know it is just a matter of time ultimately but I am keen to know what preventative measures people are taking in their RR's (I'm thinking L322's here). Do people underseal? Is there anything that can be done to protect the wheel arches and door sills beyond this?
Post #607369 26th Sep 2021 9:50am
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Waxoyl or dinatrol is your best bet, needs to be prepared first by removing all loose dirt and rust then sprayed on ideally. Done properly, IE in cavities and behind plastic trims it does work and will extend the life of the car Thumbs Up
Post #607392 26th Sep 2021 11:13am
JayGee
Unless the rust is deep and structural which will require a lot of effort you are probably best just giving it regular jet washes to remove dirt holding moisture from the usual places and keeping it outside to allow air drying or in a heated garage to dry it off. Worse place is an unheated garage. 2012 TDV8 Vogue (L322)
Post #607400 26th Sep 2021 12:30pm
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
I do the complete underside and inside the sills and box section with Lanoguard every year.
Sills and wheel arches are in fantastic shape.
Jim
Post #607410 26th Sep 2021 2:11pm
darrenm
I sprayed inside tailgate with dinatrol also removed all wheel liners and cleaned all of the rubbish out before fitting rubber edging
then gave everywhere a good spray of Lanoguard ( yearly )
Post #607483 27th Sep 2021 5:20am
