Home > Maintenance & Mods (L322) > Rust prevention strategies? |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 455 |
Waxoyl or dinatrol is your best bet, needs to be prepared first by removing all loose dirt and rust then sprayed on ideally. Done properly, IE in cavities and behind plastic trims it does work and will extend the life of the car |
26th Sep 2021 11:13am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3203 |
Unless the rust is deep and structural which will require a lot of effort you are probably best just giving it regular jet washes to remove dirt holding moisture from the usual places and keeping it outside to allow air drying or in a heated garage to dry it off. Worse place is an unheated garage. 2012 TDV8 Vogue (L322) |
26th Sep 2021 12:30pm |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 |
I do the complete underside and inside the sills and box section with Lanoguard every year.
26th Sep 2021 2:11pm |
darrenm Member Since: 06 Jan 2015 Location: chorley Posts: 182 |
I sprayed inside tailgate with dinatrol also removed all wheel liners and cleaned all of the rubbish out before fitting rubber edging
27th Sep 2021 5:20am |
