![]() | Home > Technical (L322) > Forced DPF Regeneration using Gap iid. |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3817 ![]() ![]() ![]() |
I have been asked for more details as to the procedure of performing a forced DPF Regeneration using the Gap iid tool.
Yes the live values are available in older software versions.
I had a 50+ miles trip to do this morning, so I decided to do a forced regen.
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2682 ![]() ![]() ![]() |
That’s the wife just come home , red triangle , no amber before, sitting at 31.4g. Do I just email pat for access to the beta ? |
Yes,
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
This is great news slash finally.
Cheers Mike , yes he emailed back instantly, fantastic service as usual. Firmware updated now too. I don’t have a huge amount of fuel in the car, can I fuel up after I press go? Garage is 1 mile away.
Mr Tee,
Thanks, i'll have a thread search for that |
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 ![]() ![]() ![]() |
My wife's Ewok went straight to a red DPF Full warning. Turned out it needed a software update so amber warning would show. So it's possible the same might be true in this case. What do I put here then? |
Well just back, worked like a charm. Started at just over 32g, after 25 miles was down to 2.7g. If anyone has a link to an idiots guide to checking what pipes etc before a smoke test that would be greatly appreciated. |
Because yours is an L405, it will have the later modified hoses, so much less likely to be a problem.
Mr. Tee,
