![]() | Home > Technical (L405) > Suspension bounces all over when starting after sitting |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
Sounds like there is a leak in a bag somewhere and it’s sitting down over night. Do you have any errors or codes stored?
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
I don’t think I have a leak bc I can leave it days and it won’t be on bump stops or sagging at all. It just rocks around a bit when I start it. Was thinking maybe the ARC block was the culprit. I believe that’s pretty pricey to replace…which in that case I can live with it until it fails totally.
Not sure if the ARC block would do that. the issues around that were more to do with knocking and harsh ride Afaik. There is nothing that can't be fixed with a hammer😜😜
I still occasionally get the suspension lean fault on my dash so I don’t know what the deal is. This is after replacing all 4 front LCAs and sway bar bushings (had the fault before I changed out all those things) 2014 FF Autobiography 5.0 SC
