Home > Technical (L322) > 2012 4.4 TDV8 - Steering wheel movements |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 755 |
So, it seems that I may have a (small) problem with the electrical movements of my steering wheel.
25th Sep 2021 7:50am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
As a first step, have you tried setting it the way you want with the key in ignition and then setting the memory?
25th Sep 2021 8:19am |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
Errr Weegie
25th Sep 2021 8:28am |
1. That's what I suspected. 2. I know about Easy Entry (have switched it off), but when it was on, the wheel didn't move - only the seat. Cheers! The older I get, the more I realise that people confuse wrinkles for wisdom |
25th Sep 2021 9:45am |
Sorry if I mistook your knowing of Easy Entry.
25th Sep 2021 10:06am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
Switched my EA off on Day 1. Column motor is a known weak point. Useless feature for me Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
25th Sep 2021 11:04am |
You guys with your new fangled cars. John 2008 Stornoway Grey 3.6 Tdv8 Vogue 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT 2003 Discovery TD5 Auto, Nanocom Evolution - gone to a new home! MasseyFerguson 152 - No electronics!! - Sold |
25th Sep 2021 11:16am |
No appologies needed rjff. Thanks for the links! The older I get, the more I realise that people confuse wrinkles for wisdom |
25th Sep 2021 7:25pm |
So, just to be clear, my steering wheel moves in/out/up/down, but the in/out only works with several pushes/pulls of the lever. The up/down works all the way with a single push up/down of the lever. It goes all the way in and all the way out, but I have to do half a dozen pushes /pulls on the lever to acheive this. It just moves a small amount each time and then stops.
25th Sep 2021 7:35pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8504 |
Put it where you want it, leave it alone.
25th Sep 2021 7:43pm |
That's what I've done. The older I get, the more I realise that people confuse wrinkles for wisdom |
25th Sep 2021 7:47pm |
