![]() | Home > Maintenance & Mods (L322) > L322 Gallery Pressure Not Decreasing [VIDEO] |
theanswers Member Since: 30 Jul 2012 Location: Ireland Posts: 305 ![]() ![]() |
This is the Error Code which I receive.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6743 ![]() ![]() ![]() |
I’ve got a slightly different issues in that my error is “reservoir filling too slowly” but it can raise up and down after I reset the error and hit the up/down button but that then says “vehicle lifting slowly”. After much investigation, it looks like my reservoir has a leak, so I’m awaiting a replacement from Duckworths today, so I share your frustration at the complexity of this system. Got - 2017 SDV8 Autobiography in Loire Blue
I hope you're problem has been sorted! Apologies for my slow response. I'm still trying to get mine fixed! |
I did indeed get it sorted, it was the reservoir tank, had a huge leak |
Well that would certainly cause it to fill slowly!
MartinD Member Since: 20 Oct 2010 Location: Edinburgh Posts: 303 ![]() ![]() ![]() |
Check the cables going in to the enclosure - make sure none of them have rubbed through and cause a short.
