![]() | Home > Technical (L322) > A few more questions - 4.4TDV8 differences from 3.6 |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 778 ![]() ![]() ![]() |
Having run the 4.4 for about a month now (after 13yrs of the 3.6), I've noticed a few more subtle differences which I'd like to check with others as to whether or not it's universal, or just my car.
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
Hi
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 217 ![]() ![]() ![]() |
Hi JMC. Where did you get the engine guard from? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8392 ![]() ![]() ![]() |
Baby wipes for the sat nav screen, just get one and rub gentlyish over and over in little circles and the non reflective coating will come off, you never notice the difference and it looks like a new screen when done... I used cotton buds with a wipe wrapped around for the corners... Works great...!! Pete
I changed everything when I got into the car this morning - seat, mirrors and wheel - and then pressed the Mem1 button. The seat and the mirrors returend to their correct positions, but the steering wheel didn't move. I've also noticed that when moving the wheel in and out, it only does it in short spurts, meaning that you have to press the lever forwards (or pull it backwards) several times to get any distance. There is no constant movement with a push or pull on the stalk.
Rhino Rars for the mounts and the cross-bars (TBRUK.com). Autohome for the roof tent. Sit down when getting costs..... ![]() ![]() |
Hi Pete. The underbody protection came from Solihull about ten years ago. It was on my 3.6TDV8 for the best part of a decade! Apparently, it was a LR prototype for the 2010MY and this would make sense, as it fits my 2012 more neatly than it did my 2009. It came from a 'friend of a friend' at a significant cost and I suspect it might have come out of the back door at the LR plant....... ![]() Here it was on the front of the old chariot: ![]() ![]() |
Thanks for that, been after one for a while, the only one I can find to fit is the Rival one and they don’t produce them for the L322 anymore. |
RJF
4040 Member Since: 19 Sep 2019 Location: Cornwall Posts: 44 ![]() ![]() ![]() |
Interesting. I started cleaning mine but realised a coating was coming off so stopped in case it would stop it working. I shall carry on now you say it’s ok. Also, my 2012 saves and moves, steering, seat and mirrors. |
Kiss My Carbon Footprint Member Since: 19 Dec 2020 Location: Milton Keynes Posts: 129 ![]() ![]() ![]() |
JMC,
Thanks for that Warwick. However.... I'm not sure that the issue here is the same as you had. I have full and normal adjustment for rake with smooth movement up and down from a single steady push of the lever (up or down). I also have full and normal adjustment for reach with smooth movement all the way in and out, BUT, it only works with several pushes/pulls of the lever. Each push/pull gives about 10mm of in/out movement then just stops until the lever is pushed/pulled again. The wheel goes all the way in and comes all the way out, just not in one single action. There are also no unusual noise or harshness about the movement at all. ![]() Oh!, And the wheel doesn't work at all with any of the memory settings, nor does it lift itself with ignition off. In truth, none of the above actually matters, as I rarely want to move the wheel anyway. Also, my old ('09) L322 used to throw the occasional hissy fit with the steerring wheel where it would drop to my knees at ignition on, missing it's pre-set point altogether. The older I get, the more I realise that people confuse wrinkles for wisdom ![]() |
Ah right, Ok.
In truth, that's the sort of thing I'm hopeful of. It's not affecting me on a day to day basis and I'm happy that the wheel doesn't do it's own thing every time I switch on/off the ignition. I just don't want it to be an early sign of a major failure to come. I've heard of several steering column problems on late 4.4's which have resulted in bills of the order of £4k and which even LR Assured will not take responsibility for. ![]() ![]() |
Indeed, in the course of researching possible differences between the TD6 column and that for your car I did come across an eBay seller offering complete new assemblies for the TDV8 4.4 at £3,750.
