Home > Maintenance & Mods (L322) > 3.6 tdv8 torque converter |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
Deleted |
5th Sep 2021 6:33am |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 459 |
I put shudder fix in my 3.6 at 97K (Doctor Tranny) as a temp fix, it lasted well over 50K and with regular trans oil changes, (every other service) was kept at bay. Not sure if I was just lucky but it worked on mine up to 165K when I eventually sold it. |
5th Sep 2021 4:05pm |
Wk52RR Member Since: 29 Dec 2020 Location: Devon Posts: 54 |
I’ll try the shudder fix see what that does. It might buy me some time to save pennies for a torque converter. If the shudder fix sorts the problem or lessens the juddering then is it safe to assume it’s definitely the torque converter? |
5th Sep 2021 4:18pm |
Yes I would say so, it did on mine anyway. I would change the trans fluid at the same time as the chances are it will be degraded anyway. |
6th Sep 2021 7:59am |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 |
Partial oil change may stop it if not severe. 2010 3.6tdv8 180k km.
22nd Sep 2021 11:42am |
