Home > Maintenance & Mods (L322) > Front Air Strut Replacement
Page 3 of 3 <123
Weegie
Not plastic and, although LR state it has very strong thread lock, mine had just a smear. John
GAP iiD BT
Post #606922 20th Sep 2021 3:21pm
Danwilderspin
yea he had a photo and in the next post he said it wasn't plastic - would heat help - blow torch or heatgun? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #606932 20th Sep 2021 4:45pm
dingg1
Mine came off with the help of a plumbers type grips and an impact gun.
On a side note having a right Censored of a job maintaining a seal at the bottom of these aerosus airbags, going to fit new oversized o rings soon to try and sort it, if that doesn't work then they'll be going back to deutchland for a refund Banging Head
Post #606933 20th Sep 2021 4:56pm
Weegie
@Dan
I haven't got an update but I believe he used some type of Stilson.
It won't help you but I ordered a strut for the otherside. I got Arnott and on opening the box today the vibration damper is already fitted to it! John
GAP iiD BT
Post #607056 22nd Sep 2021 11:57am
dingg1
Well it wasn't the seat at the bottom that was the real issue but one of the bags is going to be refunded, I got lucky in one respect that the old bag was ok and I was just changing the pair, otherwise I would be without transport
Bag parted from securing clamp at top
Post #607062 22nd Sep 2021 12:23pm
Danwilderspin
Still not got the top damper weights off - could I use an angle grinder take the three studs off then slowly work around the silver bit until it’s off with the weight then cut a slot to open it up then put on new setup? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #608823 10th Oct 2021 10:36pm
Weegie
Yes it's much easier if you cut of the studs on the old leg BUT I definitely wouldn't damage the silver part as you need it to go on the new strut to hold the vibration damper. John
GAP iiD BT
Post #608825 11th Oct 2021 5:42am
dingg1
I drilled a 6mm hole through the casing of the cup that holds the damper and knocked the casing round with a cold chisel, used a 14mm allen key braced against the bulkhead (all with the strut in situ)
Once you break the bond of the sealant it should just spin off, I just put them back without sealing and hand tight tbh, probably wouldn't even notice anything untoward if they weren't put back imo.
Post #608828 11th Oct 2021 8:29am
Danwilderspin
My new struts look like have a new cup on them already? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #608831 11th Oct 2021 9:07am
Weegie
If they have that would be fine but you need to be careful not to damage the thread on the damper. If you cut off the studs you might find it is easier to grip the unit.
PS. I looked at your photos again and you do appear to have the cup. John
GAP iiD BT
Post #608846 11th Oct 2021 12:07pm
fanders
United Kingdom 2009 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
Just had the ‘joy’ of doing this job today (removal of the 0.8kg damper masses to transfer over to new front struts). They were complete by££ers to remove, I ended up cutting the top studs off and holding the strut in a vice. I then ground down an old Stilson wrench so the jaws were narrow enough to hold the silver collar whilst breaking the thread locked threads free with a long 1/2” ratchet, after heating for 60 seconds with MAPP gas. But better than paying £115 a pop for new ones:
I’ve no idea why they were so well secured to the threads in the strut top, they will be going back with a few dots of Loctite 243.
Fanders
PS. I should add that the new struts (BWI via Advanced Factors, about £385 each, with forum discount) came with the threaded silver collar already installed so no need to worry about gouging up the old ones, only the damper weights are to be reinstalled. ---------------------------------------
2009 4.2 SC Buckingham Blue
2021 Hilux 2.4
Post #682630 13th Jan 2024 6:28pm
Page 3 of 3 <123
