Home > Technical (L322) > Key fob not unlocking
Boydonegood
United Kingdom 2004 Range Rover Vogue Td6 Ipanema Sand
Hi all.
Next problem!
I have 2 keys. Both always worked fine. Battery in car went flat. Jumped it and 1 key has stopped working the central locking.
Opens drivers door on key in lock (doesn’t activate the central locking) But boot and lock unlock from the key remote doesn’t work.
Key does turn in ignition and start car.
Key has new battery in..
Have tried syncing again but nothing. Lots of flashing red light on key
Old key locks and unlocks, starts etc fine so not a BCM issue?
Any ideas? Accept, some days your the pigeon, some days your the statue!
Post #606813 19th Sep 2021 3:57pm
Have you tried a battery reset? That should be your first port of call sir... Thumbs Up
Post #606825 19th Sep 2021 7:20pm
Boydonegood
Hey Craig!
Thanks so much fella. As in disconnect battery and then touch the leads together?
Would it make a difference that one key is still working correctly and the other is starting car but not operating Central locking?
Cheers fella Accept, some days your the pigeon, some days your the statue!
Post #606903 20th Sep 2021 1:39pm
Yes sir exactly that… Put it this way, it cannot cause you a problem sir, it only fixes ECU’s in distress 👍
Post #606935 20th Sep 2021 5:07pm
Boydonegood
Your an absolute star. Thank you so much. Will try tomorow!!! Accept, some days your the pigeon, some days your the statue!
Post #606937 20th Sep 2021 5:17pm
