![]() | Home > Technical (L322) > Steering column lock failed while open, ok to leave it? |
Or worse still, engage whilst driving? Not that I have heard of this happening but! If it can fail in the open position, surely it can do the opposite??? |
AlexLRV8 Member Since: 16 Sep 2021 Location: Devon Posts: 13 ![]() ![]() ![]() |
I don’t think that would be possible as it only operates (or not in my case) when the key is inserted/removed, not to mention an enormous safety oversight although I wouldn’t put it past LR. |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 594 ![]() ![]() ![]() |
What worries me is that you can still turn the key. I haven't heard of anything similar, which makes me wonder if there's something more to consider before you can safely drive itlike this. I'm having my column repaired tomorrow (stuck unlocked but can't turn key unless fuse is removed) and I could ask whether your case could be something dangerous or nothing to worry about. |
Thank you that would be great if you can ask your mechanic.
Yes, that's how it works. However, every time the key is removed and re-inserted, a full cycle has to be registered by the immobilizer i.e. lock->unlock confirmation before the key can be allowed to turn.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8369 ![]() ![]() ![]() |
IIRC the later post 2005 cars have a "better" system in that it doesn't go looking for an unlock signal from the steering column before it lets you turn the key, I remember wishing fatty offroader had a later system...
My employer's 2008 SC had exactly the same symptoms as mine i.e. key not turning and the same "securing magnet fault/locking operation error". From what his mechanic told me, it's all the same as the 02-05 BWM derived barrel and column system, the only difference being the barrel installation position. |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1351 ![]() ![]() |
Mine failed in the locked position, fortunately I was parked up at home, I've disabled it so that it now cannot fail again, but in doing so have no steering lock |
Mechanic said it should be checked, as it's being able to start after removal and re- insertion of key, without pulling the battery negative or the fuse (?) does seem awkward. He wouldn't go into further details as they're having a very busy day with a dozen range rovers inside and outside their garage.
