Home > Technical (L322) > Heater motor removal L322 MK3 2011 Help a Idiot please |
Bigbill2656 Member Since: 14 Sep 2021 Location: Aberdeen Posts: 33 |
I have seen people have done this job but by cutting things Id like to do this and have a complete car after if at all possible. I have searched the site all evening but havent found what I need.
14th Sep 2021 9:25pm |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
Unfortunately you will have to remove the centre consul to access the surround retaining screws. |
15th Sep 2021 7:07am |
thank you I thought as much. |
15th Sep 2021 7:16am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7801 |
If you download the Workshop Manual from the Wiki, all the instructions are in there.
15th Sep 2021 8:46am |
I have a workshop manual on disk but its useless it doesn't show all the work to be carried out to remove the reinforcing dash panel. I spent hours going through it page by page. I can't find another one on Wiki I did a search nothing came up if you have a link I'd appreciate it.Thanks
15th Sep 2021 9:35am |
The Wiki button is at the top right, under the Fullfatrr bit.
15th Sep 2021 9:54am |
Is that the one you have already? Proper Land Rover one in a series of PDFs… so it should cover it somewhere…. 2011 Range Rover Vogue SE 4.4 TDV8
15th Sep 2021 9:58am |
Yes it is the Land Rover one 5000 pages long but i can't find what i need. I have the one vent that goes from the rear of the speedo to a little fan by your legs took that fan out and got the vent uncoupled. I am sure now that the centre console must come out as there are two plastic pins that go from it straight in the the dashboard reinforcement panel. I have all the top moving but the middle where all the vent pipes are and the bottom are tight as hell. I am trying not to force stuff but im getting so frustrated. trying to get centre console moved now I tried undoing the 4 bolts by the rear blower but that didn't lose anything. I can see a bolt coming from the seat side inwards but that seems to be behind the leather sides of the console. removed all but 2 screws which i cant get to without taking all the back equipment off as tow are impossible to get to the are almost hidden by the pipe going up top the rear vents. unlike the front ones not found how to remove that part either. I have thought of getting it towed to the professionals but I really want to complete what I started. As I am just getting over getting most my lymph nodes removed I haven't had much to do so I just wanted a task. Not sure I should have started this |
15th Sep 2021 1:10pm |
thanks I never saw that. Bill |
15th Sep 2021 1:12pm |
Yes, you aren’t the first to not spot it…. And won’t be the last.
15th Sep 2021 2:14pm |
I don't now know what to do from here. If i could post pictures i could ask where to go which part contains the motor is it right by the windscreen? I cant see how to get any of it out I saw 2 nuts at the bottom front but they seem to be just rubber bushes. the only part i can see that looks the shape of the fan is right under the harness by the windscreen but I undid 4 screws in front of that and they didnt do a thing. I was told it was held in by 4 bolts from the top going towards the floor but I can't see anything like that.
15th Sep 2021 5:30pm |
Photos eventually off my phone computer wouldn’t do it.
15th Sep 2021 5:38pm |
15th Sep 2021 6:55pm |
These are the photos and I now know it is the top part just have to figure out how to get the cover off. |
15th Sep 2021 6:58pm |
