Home > In Car Electronics (L405) > Seatbelt warning light.
GrandadRob
England 2013 Range Rover Vogue SE SDV8 Luxor
When I start the engine, the usual car shape appears in front of driver. When I put my belt on, it shows a green tick In the seat position on the diagram, and goes off. When I have a front seat passenger, the same thing happens. But then an amber seatbelt sign illuminates to the left on the dash, even though the belt is fastened, no bongs just light. Any thoughts please.
Post #605804 7th Sep 2021 6:39am
millerj90
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
Could it be a warning that youve got the child safety seat switch set?
Post #605821 7th Sep 2021 10:35am
spbee
what model year do you have ? i cant find a reference to an amber seat belt sign in the handbook, only a red one, is it the airbag warning light ?
Post #605855 7th Sep 2021 5:43pm
GrandadRob
Not sure of model year , first registered November 2013. Vogue SE.
Post #605876 7th Sep 2021 9:07pm
spbee
can you post a pic of the light ?
Post #605878 7th Sep 2021 9:13pm
GrandadRob
Just read it maybe airbag warning light, any thoughts.
Post #605879 7th Sep 2021 9:14pm
It’s the airbag warning light. Have you moved the seat around much recently. can be a problem with the under seat wiring
For the airbags which cause the light to come on iirc. Happened once on mine, but hasn’t recurred. There is nothing that can't be fixed with a hammer😜😜
Post #605880 7th Sep 2021 9:16pm
GrandadRob
It’s new to me, so have been experimenting with seat positions.
Post #605881 7th Sep 2021 9:19pm
GrandadRob
Thanks Guys, great help as usual. Yep, seatbelt sign, loads online, including here. Seems intermittent, some say wiring behind seat back, some say outside temperature, others say the car is haunted because no faults found. But I did find an airbag recall in 2013 for SDV8 models.
Post #605891 8th Sep 2021 7:16am
GrandadRob
UPDATE......
After listening to your advice, I went under the front seats and gently moved the wiring. Guess what, no airbag light. Just one other question, is there an airbag light on each side to indicate which side is faulty ?s
Post #605921 8th Sep 2021 11:13am
no just the one warning light with no indication which side has the problem. Sounds like a loose connection which was what was causing the issue on mine. Id put the seat right back and down which obviously knocked something out of position. Once the seat was back up I had a google and a prod under the seat and everything went back to normal. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #606003 9th Sep 2021 6:05am
