Home > Camping, Caravanning and Holidays > First time towing a tintent any tips for a novice
Furnitureman
United Kingdom 2012 Range Rover Westminster 4.4 V8 Cairns Blue
Having towed everything from a small camping trailer to a tri axle iffor williams box trailer maxed at 3.5t with my old disco I’m off to Carfest in the morning pulling a single axle tintent for the first time, I’ve loaded the van to get the correct nose weight, all tyres inflated correctly I’m happy pulling trailers, reversing and parking just wondered if there is anything different to think about 2012 Range Rover Westminster 4.4 TDV8
2006 Discovery 3 HSE 260k miles and still going strong with a new owner
Post #604849 26th Aug 2021 5:21pm
TJH1985
Full tank of fuel Rolling with laughter if you take it steady the MPG isn’t too bad that being said.
I tow a twin axle van with the RR sometimes, and honestly you could forget it’s there.
I towed a horse box previously and moving to a van was much easier, after I got over being a little nervous about the value of the van. Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #604854 26th Aug 2021 6:23pm
Furnitureman
Not bothered about the MPG it’s better than the disco so that’s ok and it pulls like it’s not on 2012 Range Rover Westminster 4.4 TDV8
Post #604860 26th Aug 2021 6:45pm
TDV8 - towing is a pleasure - just remember you have a caravan on the back Thumbs Up it's easy to forget Very Happy
Post #604864 26th Aug 2021 7:15pm
James W
Saudi Arabia 2017 Range Rover Autobiography SDV8 Siberian Silver
Nose weight is the biggest factor affecting my twin axle caravan, too heavy and it bobs, too light and it sways (only slightly, but get it perfect and it's bliss). Other than that, I scan my route on google earth on any tight spots/towns etc to look for any potential issues or restrictions. Also recce potential stopping places online in case needed. And finally - relax and take your time. I always try to slow right down and really concentrate when hitching up, setting off, etc. FFRR SDV8 Autobiography
Post #604885 26th Aug 2021 9:03pm
crowebeard
United Kingdom 2012 Range Rover Westminster 4.4 V8 Orkney Grey
I'm in the same boat, going to Carfest and towing the tintent for the first time with the new FFRR. Expecting a slightly easier journey this time round! David
2012 Range Rover Westminster 4.4TDV8
2004 Range Rover Vogue 4.4 V8 (LPG) (Not quite gone)
2021 Mazda CX-5
2003 Porsche Boxster
Post #604886 26th Aug 2021 9:07pm
Don't forget the flat cap, don't drive anywhere near the speed limit and don't look in your mirrors... Rolling Eyes Laughing Pete
Post #604935 27th Aug 2021 12:47pm
TJH1985
One thing I would say, keep a eye out for people who feel they MUST be in front of the slow caravan, without considering that the 12/13m car and caravan combination has no problem keeping with traffic and is quite a big overtake.
Had quite a few people run out of room trying to push past, especially when it goes from 2 to 1 lane and they are still level with the caravan because they are the 6th / 7th car trying to get past off a set of lights. Likewise people making risky overtakes without considering the length. Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Post #604937 27th Aug 2021 12:59pm
Sean
England 2007 Range Rover Vogue SE TDV8 Java Black
Take your time and enjoy the journey. I used to stick to 60 towing with no problems.
Post #605794 6th Sep 2021 10:38pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Exactly, too easy to forget the trailer, I have been at silly speeds with 2 horses up, although hopefully a caravan will tell you Thumbs Up
Post #605797 6th Sep 2021 10:51pm
single axle vans are less stable than a twin, but you should have no problem towing pretty much any van with the 322.
remember its wider than the car, adjust your towing mirrors so you can see properly before setting off, you seem to have thought of most of the rest of the important things. Make sure the lights work on the van, remember to check the windows, fridge, roof lights, and TV aerial are down or shut, the amount of vans I see on he Mway with the aerial still up......
Also remember to switch the fridge to battery setting before you set off, it will only come on if the car is running and connected.
Take it steady, and don't be tempted to belt along at 80, even though it feels like the car could, it can go wrong pretty quickly. There is nothing that can't be fixed with a hammer😜😜
Post #605802 7th Sep 2021 7:33am
