Home > Technical (L322) > 2004 M62 V8 4.4 Engine & Gearbox operating temperature |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 584 |
Playing with the IID tool and getting to know my vehicle's operating parameters better ... Noticed the gearbox temp on the high (118C) side the other day. So today I took her for a 50km drive to my folks, logging some health data along the way.
5th Sep 2021 5:07pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
Anything over 100c and you are damaging the ATF fluid, I expect your transmission oil thermostat is worn out and maybe the main rad is blocked at the bottom where the gearbox cooler takes it's supply... Very common on yours and it will reduce the life of the box if not sorted... Pete
5th Sep 2021 7:24pm |
Funny thing the radiator, transmission thermostat, connecting manifold of oil cooler to the radiator (or whatever they call it) and oil cooler itself are new! (Less than 2 years old)! Actually some of the very first things I replaced on the vehicle.
5th Sep 2021 7:28pm |
Should run around 80c as I said over 100 and the oil begins to deteriorate...
5th Sep 2021 9:40pm |
Thanks Pete
6th Sep 2021 3:27am |
So, had a word with ZF representatives over the phone. As per their procedures for new installations testing, the ATF temperature should not exceed 120C during performance testing.
6th Sep 2021 9:45am |
They can sludge up pretty quick but not so much if you are changing the fluid often...
6th Sep 2021 10:46am |
Unnecessary quote removed
6th Sep 2021 11:12am |
And that's because it's running so hot, get it changed and everything will be a lot better... Pete
6th Sep 2021 11:28am |
Mine was particularly susceptible to this kind of failures as it had been sitting for 4 years! I did my best inspecting all things of major concern before purchasing and doing the necessary fluid changes afterwards. So far she hasn't let me down considering the acquisition price as she was exactly what I had been looking for; a solid foundation to work on and use as a tool vehicle. |
6th Sep 2021 11:36am |
