Home > General > 2007 TDV8
paul271
Scotland 2002 Range Rover Vogue Td6 Epsom Green
2007 TDV8
Need to pick your collective brains again guys!!
Is the box on an 07 3.6 TDV8 still as problematic as the early L322 boxes?
Also I'm completely unfamiliar with the engine. What would be the main things to look out for?
Thank you in advance guys.
Post #605559 4th Sep 2021 11:46am
paul271
Been having a trawl through old threads and I see turbos come up. I was under the impression the v6 only has 1 turbo and the v8 has 2?
Post #605562 4th Sep 2021 1:01pm
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Hi Paul, they never put a TDV6 in the L322, only the sport and disco had the TDV6. They went to TDV8 from the TD6 in late 2006 which was a 3.6 v8 with twin turbo’s.
The gearbox was also a huge improvement going to the ZF 6 speed which was more up to the job of the L322’s weight.
Reliability wise there’s lots on here about turbos and EGR valves ECT, but if you get a well maintained one and look after it they can be a reliable vehicle. Towing with them is awesome compared to the TD6.
I came from a TD6 to the 3.6 TDV8 which I owned for 5 years and loved it.
I changed the EGR valves at around 100K and the alternator at 130K, other than that was just routine maintenance up to 167K when I traded her in.
Post #605566 4th Sep 2021 1:46pm
paul271
Sorry mate. I got my numbers codes all mixed up!!! 🤣
Does the 3.6 have twin turbos or just one?
Post #605567 4th Sep 2021 2:14pm
Weegie
Twin - one for each bank. John
GAP iiD BT
Post #605569 4th Sep 2021 2:26pm
paul271
Thank you guys. Might check out a few 3.6's through the week.
Post #605598 4th Sep 2021 7:34pm
The tdv8 box is definitely more reliable than the Gm box in the td6. Not completely problem free, but in general is pretty robust, nice fluid and filter change or a bodsyflush will help prolong life 👍🏻 There is nothing that can't be fixed with a hammer😜😜
Post #605868 7th Sep 2021 7:31pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Re: 2007 TDV8
Did gearbox filter and oil at 76k on mine. Now on 130k so dropped the fluid and did a basic fluid change last week ( didn't have a filter or time to go the whole hog ). Can feel a difference just through changing the fluid.
Post #605900 8th Sep 2021 8:28am
