![]() | Home > Maintenance & Mods (L405) > Long term oil dilution problem/solutions |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4320 ![]() ![]() ![]() |
Is the DPF working properly and regenerating or simply requesting too many regens and hence the oil dilution?
eazlth Member Since: 31 Aug 2021 Location: Derbyshire Posts: 7 ![]() ![]() |
The DPF light hasn’t come on over the last 24,000 miles, so I guess the DPF regen is working OK.
you don't say what engine you have. This may be a bigger problem if it's a TDV6 rather than the TDV8. Jags and Ewoks are finding this problem. It's caused by the DPF initiation pumping extra fuel to the pdf to raise temps. If your car isn't doing a regen properly it will pump unburnt fuel and this can make its way into the crankcase. |
Yes it’s the 3.0 TDV6.
ABAB Member Since: 02 Feb 2017 Location: GB Posts: 287 ![]() ![]() ![]() |
In case it’s any help, I have a 2016 SDV8 and have typically been getting 12,000 miles between services. 2016 SDV8 AB |
Thanks ABAB, that just makes me envious |
Out of interest, is the service interval indicator on the InControl App or in the car linked to the online service history in any way? My last service wasn’t recorded on the website and when I logged on it said that there was an urgent bulletin. I called the dealership and they updated the record and the bulletin on the website disappeared. Could this have brought the service light on? |
Just got back from a weeks holiday in Norfolk and the service indicator is now at zero.
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1261 ![]() ![]() |
FIRST
Hi KOT
Thats good news getting it in tomorrow, ask them to test the oil, for oil dilution, dont be fobbed off, they can do this.
TonyHammer61 Member Since: 14 Sep 2023 Location: Sidcup, Kent Posts: 11 ![]() ![]() ![]() |
Would removing the DPF solve my oil dilution problems on my 4.4 SDV8? |
Yes it would!
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1590 ![]() ![]() ![]() |
Hi Tony,
