![]() | Home > Technical (L405) > Knocking noise from offside front |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1214 ![]() ![]() ![]() |
Sounds like something on the suspension could be a likely culprit.
chris595959 Member Since: 09 Jan 2012 Location: Brighton Posts: 62 ![]() ![]() |
Sounds like it may be a joint on the front suspension .
shiversaint Member Since: 16 Aug 2021 Location: Sussex Posts: 9 ![]() ![]() ![]() |
Thanks both. I'll call the dealer today.
Hi Sorry I don't know of any in the area |
Bora20 Member Since: 03 Mar 2021 Location: Kamloops, BC Posts: 238 ![]() ![]() ![]() |
I have a knock at low speed when going over bumps, high speed on both sides when hitting bumps, and a wandering front at times. A large knock on the left side when accelerating hard too. Independent states the sway bar end links and lower front forward control arms have play. Replacements are sitting at my front door waiting on the ball joint tool delivery. Am replacing all tomorrow afternoon myself with hopes that solves the problem.
jackcramerr Member Since: 13 Oct 2019 Location: London Posts: 220 ![]() |
Bora20
aja500 Member Since: 15 Oct 2017 Location: South East Posts: 826 ![]() ![]() ![]() |
I've never used these people, as I live in Heathfield and have a very good local Indy (although probably too far for you), but these people are on my list for a Waxoyl Treatment. They seem quite serious about Land Rover's and have good Google reviews. It's still a bit of a trek for you, but I noticed they do offer free loan cars: https://www.terrainvehicles.co.uk/ |
This sounds similar to part of my problem, although the biggest issue I've noticed, is the drive has become much firmer and I'm feeling every single bump in the road - Have you experienced similar in terms of deterioration of ride quality? |
I installed the sway bar end links and lower front forward control arms this week. It took me roughly three hours. The ball joint tool was not needed, although I had it in case I did.
I feel every bump, increase in tram lining, and the front end feels like it is on ice. Constant steering wheel corrections. Bumps on the passenger side create noises on the drivers side. Hard acceleration from a rolling stop result in a loud bang on the left side (drivers). The sway bar ends links and lower front forward control arms have firmed up everything. There is still a bang on hard acceleration, but it is softer and much less pronounced. The lower front rearward control arm replacement should resolve this issue. These components are definitely items I would replace together along with the sway bar bushings. |
Thanks Bora20, that's a big help and mine shares many similarities.
Thanks! If you aren’t handsome, you should be handy.
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 462 ![]() ![]() ![]() |
Definitely go with the lower arms, they have a big bush at the front which wears with age then knocks, also the D bushes or sway bar bushes are common, done mine and it was like a different car once done. |
