Home > Technical (L405) > Knocking noise from offside front
shiversaint
United Kingdom 2013 Range Rover Vogue SE SDV8 Balmoral Blue
Hi all,
Bought a 2013 SDV8 Vogue SE with 77k a couple of weeks ago, and I've begun to notice an easily replicated knocking noise that does not sound healthy. When manoeuvring the car at sub 5mph with a fair amount of steer (reversing or turning into parking bays), I hear clunk from the front right of the car. You don't really feel it in the steering, it doesn't seem rotational but it does seem to "wind up", so the tighter the turn the louder it'll be - almost as if there is pressure building and then releasing as a part finally moves under strain. I think it is getting worse.
I have the car booked in at a local but not specialist, but just want to make sure I go in with my eyes wide open. I wouldn't describe it as a judder so I don't think it's the transfer case thing, but regardless I am having all drive fluids changed at the same time (trans, diffs, transfer and engine oil - former three never been done afaik).
Rejecting it back to the dealer isn't really on the cards right now as it's a pretty unique spec that took me months to find. It is otherwise faultless and drives at high speed very well.
Any ideas what it could be? TIA
Post #605159 30th Aug 2021 9:49am
Merchy
Sounds like something on the suspension could be a likely culprit.
Whilst you said that rejecting the car is not on the cards, you should be able to get the seller to carry out repairs as there are legal safeguards / rules in place. Especially as the fault has occurred within such a short time period.
If your local garage can identify the problem, then go to the dealer and get THEM to fix it. I am quite sure they will be legally bound to do so.
First step to take is to at least inform the selling dealer of the problem ASAP to protect your 'Consumer rights'
Post #605171 30th Aug 2021 11:33am
chris595959
2015 Range Rover Autobiography 5.0 SC V8 Mariana Black
Sounds like it may be a joint on the front suspension .
Try and find an MOT testing station that runs a one man testing lane as they will have shaker plates
Offer them a few quid to have it shaken and that will show up the culprit
Post #605185 30th Aug 2021 2:35pm
shiversaint
Thanks both. I'll call the dealer today.
Chris I see you're in Brighton - I'm in Worthing. Can you recommend a local garage in the area by any chance?
Post #605238 31st Aug 2021 8:16am
chris595959
Hi Sorry I don't know of any in the area
Post #605277 31st Aug 2021 8:00pm
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
I have a knock at low speed when going over bumps, high speed on both sides when hitting bumps, and a wandering front at times. A large knock on the left side when accelerating hard too. Independent states the sway bar end links and lower front forward control arms have play. Replacements are sitting at my front door waiting on the ball joint tool delivery. Am replacing all tomorrow afternoon myself with hopes that solves the problem.
Cost is 1/3 of what the independent wanted and they quoted aftermarket parts which I am using too. The tool pushed the cost to 1/2 of the cost, but the tool will be used again or resold for the original purchase price.
Post #605326 1st Sep 2021 2:30pm
jackcramerr
Bora20
Please do post pictures and details of tools use and any issues you come across. Love people who DIY and share.
Post #605330 1st Sep 2021 2:59pm
aja500
United Kingdom 2019 Range Rover Autobiography 5.0 SC V8 Aruba
I've never used these people, as I live in Heathfield and have a very good local Indy (although probably too far for you), but these people are on my list for a Waxoyl Treatment.
They seem quite serious about Land Rover's and have good Google reviews.
It's still a bit of a trek for you, but I noticed they do offer free loan cars:
https://www.terrainvehicles.co.uk/
Post #605583 4th Sep 2021 4:39pm
aja500
This sounds similar to part of my problem, although the biggest issue I've noticed, is the drive has become much firmer and I'm feeling every single bump in the road - Have you experienced similar in terms of deterioration of ride quality?
Post #605584 4th Sep 2021 4:42pm
Bora20
I installed the sway bar end links and lower front forward control arms this week. It took me roughly three hours. The ball joint tool was not needed, although I had it in case I did.
I used hand tools and a 1/2’ cordless impact to remove to ball joint 36mm 12-point nut. I did it on the floor of my friends garage without a lift. I needed a second set of hands to insert the control arms into the frame and to achieve the correct torque due to limited mowing of the torque wrench and breaker bar. On a loft I would not have needed help.
I also found the lower front rearward control arms to have lateral movement at the subframe. I ordered new ones and will install in two weeks once they arrive.
At this time, I have a remarkable improvement. The ball joints of the sway bars end links and front control arm were beyond shot. I can move them with one finger. The new ball joints ok my entire hand and force to move them.
I used and will be using Mevotech Supreme components. They may not be as good as some, but they are 1/3 the cost of OEM and I need a price break at this time due to other personal matters. I only drive about 10,000 km/yr so they should last a few years at minimum.
I will get an alignment once the rearward arms are installed.
I followed the steps in the OEM manual and others as outlined in this link: https://www.rangerovers.net/threads/l405-2...st-2346897
Post #605585 4th Sep 2021 4:43pm
Bora20
I feel every bump, increase in tram lining, and the front end feels like it is on ice. Constant steering wheel corrections. Bumps on the passenger side create noises on the drivers side. Hard acceleration from a rolling stop result in a loud bang on the left side (drivers).
The sway bar ends links and lower front forward control arms have firmed up everything. There is still a bang on hard acceleration, but it is softer and much less pronounced. The lower front rearward control arm replacement should resolve this issue.
These components are definitely items I would replace together along with the sway bar bushings.
Post #605588 4th Sep 2021 4:48pm
aja500
Thanks Bora20, that's a big help and mine shares many similarities.
Wish I was more hands on - Sounds like you've done a fantastic job Thumbs Up Thumbs Up
Post #605589 4th Sep 2021 4:53pm
Bora20
Thanks! If you aren’t handsome, you should be handy.
I also replaced the stretch bolts as per JLR. And extra $150 🇨🇦, but I figured I should do it right. An alignment will occur once the other control arms are in place.
I will take a few pix once all buttoned up.
Post #605604 4th Sep 2021 8:07pm
aja500
Laughing Laughing Laughing
I used to be handsome, but my friends Mr Pinot and Mr Grigio, combined with my love of good cheese and fine foods in general, put an end to my good looks some time ago!!!
I'm sure I'm not on my own, and there are other members on here who have also fallen victim.
Look forward to seeing the pics Thumbs Up Thumbs Up
Post #605617 4th Sep 2021 10:37pm
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Definitely go with the lower arms, they have a big bush at the front which wears with age then knocks, also the D bushes or sway bar bushes are common, done mine and it was like a different car once done.
Post #605650 5th Sep 2021 4:12pm
