Home > Off Topic > Kitchen Hob Downdraught Extractors
RR2B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
Anyone here comment on the effectiveness or otherwise of hob downdraught extractors, specifically the Bora? In the process of a major refurb, and need to decide whether to duct up or duct down. Downdraught is neater, with no annoying canopy in sightline, but as heat rises logic says they cannot be as effective. Or are they?
Any opinions appreciated. 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #604281 20th Aug 2021 2:58pm
Furnitureman
United Kingdom 2012 Range Rover Westminster 4.4 V8 Cairns Blue
I’ve fitted a few different ones in customers houses inc my own, the ones with the extraction in the centre are better than the ones with the extraction at the edges that said if your steaming food neither are great at extracting the steam when the top of the lid is over 12” away, also you loose a lot of the cabinet below and the ducting can be a pain 2012 Range Rover Westminster 4.4 TDV8
2006 Discovery 3 HSE 260k miles and still going strong with a new owner
Post #604282 20th Aug 2021 3:01pm
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
Definitely form over function. Having looked seriously at them, I ended-up going flush in the ceiling with a large Westin and a huge in-line fan. Not so easy to do unless you're in a bunglaow. Wink The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #604284 20th Aug 2021 3:18pm
Also went with Westin, but just the filter set and lights in the flush ceiling fitting. I ducted that through the ceiling and up to the loft and mounted the inline fan in the loft which keeps all of the noise out of the kitchen. Works a treat. Was during a major project here and was able to put in a false wall in a bathroom above to hide all of the bathroom plumbing as well as the ducting for the kitchen extractor. Mike - MPx
Post #604291 20th Aug 2021 4:34pm
Never found extractors do much other than blow smoke around the room…..
Building regs need all new builds to duct out (or a big 6” fan in the wall somewhere..) I have installed pretty much all types, rise up downdraught types, in ceiling flush and canopies. The best I’ve found is the is flush in-ceiling type, with a 6” rigid duct to outside.
If you are thinking of putting the hob on an island then it’s virtually impossible to duct out a downdraught extractor so it would have to filter and recirculate, which is next to pointless…. There is nothing that can't be fixed with a hammer😜😜
Post #604300 20th Aug 2021 8:03pm
RR2B
Thanks for all the help and advice. Still undecided - up draught or down draught, ducting is going to be a challenge with two foot thick walls! 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #604652 24th Aug 2021 11:32am
Kitchen canopies both domestic and commercial evolved and are used because they work. Thumbs Up
Post #604653 24th Aug 2021 11:45am
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Ours works fine, ducted up through the ceiling to an outside wall, all smoke and steam efficiently removed. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #604657 24th Aug 2021 1:32pm
My point is less that they do absolutely nothing but that they do nowhere near what they are supposed to do. We have a fan test kit so we can check the extractor performance once installed before they are tested for building regs. it’s all about the ducting, a kitchen fan should achieve a min of 30l/s if above or adjacent to a hob according to building regs, most extractors will just about do this, even with rubbish ducting, but the specs of the appliance will boast about how they can do 180 l/s. That is in free air with no duct….
Eg, the Neff extractor we just installed quoted 180l/s but when on the end of 3m of 100mm flexi duct it achieved 32 l/s which is a pass but marginal. The duct was nice and straight and not crimped etc.
My ceiling extractor ducted with 6” solid duct gets 76 l/s which is brill but it’s spec says 277l/s or 1000m3/hr.
We’ve been asked on the next house we are doing, to install an extractor hob, slightly worrying as it starts from a slightly lower performance point and will probably end up with similar losses.
Bathroom fans are another issue, even good branded fans are next to useless, so have a manrose fan in my utility and it gets 8l/s straight through the wall with solid duct…..so care is required when picking the exact fan for a particular use. There is nothing that can't be fixed with a hammer😜😜
Post #605049 28th Aug 2021 2:30pm
AJGalaxy2012
Interesting points for sure and I hear what you say about the drop in performance. From my perspective, the end user, if I have 4 pans of boiling water on the hob and the extractor successfully removes the steam from my kitchen that's a result I'm interested in. BMW i3 Electric Car
Post #605057 28th Aug 2021 3:04pm
RR2B
We are now thinking of going industrial with something like this https://shop.systemair.com/en/prio--silent--xp--150ec/p504350 pulling air from one end of the room at high level (kitchen approx 7m x 5m) through short trunking direct outside. This would be approx 3m from the hob and oven location, would this give sufficient air flow?? 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #605246 31st Aug 2021 10:08am
AJGalaxy2012
Where does the air come in for it 'flow' you would need an air inlet at the opposite side. It seems awfully complicated just to avoid a duct through the ceiling void. BMW i3 Electric Car
Post #605269 31st Aug 2021 5:45pm
It should, as it’s spec is 500m3 in free air, generally speaking a 6” fan is what is required if not using an over hob or canopy unit. when not positioned over the hob the fan needs to have better performance 60l/s rather than 30 over a hob. Short rigid duct will help, but if you are doing a refurb then it’s unlikely the LaBC will test it in any case, rather just look to check you have a 6” fan. There is nothing that can't be fixed with a hammer😜😜
Post #605379 2nd Sep 2021 6:48am
ilard
I use a downie by Elica. It’s weak if you’re used to quality overhead solutions. Weak but not useless. I would advocate a downdraft extractor coupled with a room extractor fan, but when I tried to upgrade our solution to include a room extractor for the kitten my wife rejected on aesthetic grounds (without evaluating and without me pushing).
In short, even if you upgrade the motor for a downdraught extractor it is working against gravity and they’re not especially effective. Aesthetically superior though for many installations. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #605529 3rd Sep 2021 10:14pm
