Home > Off Topic > Kitchen Hob Downdraught Extractors |
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 350 |
I’ve fitted a few different ones in customers houses inc my own, the ones with the extraction in the centre are better than the ones with the extraction at the edges that said if your steaming food neither are great at extracting the steam when the top of the lid is over 12” away, also you loose a lot of the cabinet below and the ducting can be a pain 2012 Range Rover Westminster 4.4 TDV8
20th Aug 2021 3:01pm |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 755 |
Definitely form over function. Having looked seriously at them, I ended-up going flush in the ceiling with a large Westin and a huge in-line fan. Not so easy to do unless you're in a bunglaow. The older I get, the more I realise that people confuse wrinkles for wisdom |
20th Aug 2021 3:18pm |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 587 |
Also went with Westin, but just the filter set and lights in the flush ceiling fitting. I ducted that through the ceiling and up to the loft and mounted the inline fan in the loft which keeps all of the noise out of the kitchen. Works a treat. Was during a major project here and was able to put in a false wall in a bathroom above to hide all of the bathroom plumbing as well as the ducting for the kitchen extractor. Mike - MPx
20th Aug 2021 4:34pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8523 |
Never found extractors do much other than blow smoke around the room…..
20th Aug 2021 8:03pm |
RR2B Member Since: 04 Aug 2020 Location: Rowlands Castle Posts: 251 |
Thanks for all the help and advice. Still undecided - up draught or down draught, ducting is going to be a challenge with two foot thick walls! 2011MY 4.4TDV8 Autobiography Baltic Blue
24th Aug 2021 11:32am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
Kitchen canopies both domestic and commercial evolved and are used because they work. |
24th Aug 2021 11:45am |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
Ours works fine, ducted up through the ceiling to an outside wall, all smoke and steam efficiently removed. BMW i3 Electric Car
24th Aug 2021 1:32pm |
My point is less that they do absolutely nothing but that they do nowhere near what they are supposed to do. We have a fan test kit so we can check the extractor performance once installed before they are tested for building regs. it’s all about the ducting, a kitchen fan should achieve a min of 30l/s if above or adjacent to a hob according to building regs, most extractors will just about do this, even with rubbish ducting, but the specs of the appliance will boast about how they can do 180 l/s. That is in free air with no duct….
28th Aug 2021 2:30pm |
Interesting points for sure and I hear what you say about the drop in performance. From my perspective, the end user, if I have 4 pans of boiling water on the hob and the extractor successfully removes the steam from my kitchen that's a result I'm interested in. BMW i3 Electric Car
28th Aug 2021 3:04pm |
We are now thinking of going industrial with something like this https://shop.systemair.com/en/prio--silent--xp--150ec/p504350 pulling air from one end of the room at high level (kitchen approx 7m x 5m) through short trunking direct outside. This would be approx 3m from the hob and oven location, would this give sufficient air flow?? 2011MY 4.4TDV8 Autobiography Baltic Blue TVR Griffith Alfa Romeo Mito QV |
31st Aug 2021 10:08am |
Where does the air come in for it 'flow' you would need an air inlet at the opposite side. It seems awfully complicated just to avoid a duct through the ceiling void. BMW i3 Electric Car
31st Aug 2021 5:45pm |
It should, as it’s spec is 500m3 in free air, generally speaking a 6” fan is what is required if not using an over hob or canopy unit. when not positioned over the hob the fan needs to have better performance 60l/s rather than 30 over a hob. Short rigid duct will help, but if you are doing a refurb then it’s unlikely the LaBC will test it in any case, rather just look to check you have a 6” fan. There is nothing that can't be fixed with a hammer😜😜
2nd Sep 2021 6:48am |
ilard Member Since: 21 Oct 2012 Location: London Posts: 712 |
I use a downie by Elica. It’s weak if you’re used to quality overhead solutions. Weak but not useless. I would advocate a downdraft extractor coupled with a room extractor fan, but when I tried to upgrade our solution to include a room extractor for the kitten my wife rejected on aesthetic grounds (without evaluating and without me pushing).
3rd Sep 2021 10:14pm |
