Home > Maintenance & Mods (L322) > How long will a brand new battery last before fitting |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
Not on a FF but on my M/C I had a new battery sitting for over 2 years due to circumstances and after charging up with a "conditioner" it worked. Admittedly the wet acid type and the acid was not filled until put into use.
27th Aug 2021 2:10pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8530 |
I would imagine it will be pretty much as good as new. A few extra months on the shelf won’t have hurt it. I doubt it will even need a charge. But as above check the voltage and put it on charge overnight if it’s a bit low. There is nothing that can't be fixed with a hammer😜😜
28th Aug 2021 3:37pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
I have had an old battery sitting about in my garage for a couple of years. Still shows 12+ volts when I check it, but doubt if it would crank a TD6 without a good charge .
28th Aug 2021 4:10pm |
