![]() | Home > Technical (L322) > Stranded again ! |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2275 ![]() ![]() ![]() |
Might not be the cause but when I had intermittent starter problems on both the p38 and the l322 it was because the cables had internal corrosion put an additional cable in and in both instances problem disappeared |
Gordo51 Member Since: 16 Jul 2018 Location: Chilliwack Posts: 16 ![]() ![]() ![]() |
"In fully charged condition @ 11.4~11.5"
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 ![]() ![]() ![]() |
Thats at the starter relay coil |
aids22 Member Since: 10 Jun 2019 Location: Warrington Posts: 27 ![]() ![]() ![]() |
I had the same problem after changing the alternator. Anybody who has replaced the alternator you will know that it is quite a strip down, disconnecting the battery is also required.
TeeMyob Member Since: 22 Jun 2019 Location: Javea/Manchester/Abu Dhabi Posts: 206 ![]() ![]() ![]() |
Just to update.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3162 ![]() ![]() ![]() |
Our 4.4 TDV8 went through multiple starts within the first 21k miles (3 in total) and we all changed by the Land Rover dealer. It then failed on us again in September 2019 at which point I fitted a Denso one that we sourced from Euro Car Parts and it’s been fine for nearly 3 years now.
