Home > Technical (L322) > Stranded again !
cass
And again[/quote]
When mine was misbehaving I fed a wire from the starter solenoid up to the battery, whenever it decided to not start I could activate the starter by touching it to the +ve terminal - worked every time.
I've still left it on now that it's fixed for peace of mind, every RR should have one!
Post #604926 27th Aug 2021 11:16am
Sandyt
Might not be the cause but when I had intermittent starter problems on both the p38 and the l322 it was because the cables had internal corrosion put an additional cable in and in both instances problem disappeared
Post #604972 27th Aug 2021 3:28pm
Gordo51
Canada 2008 Range Rover Supercharged 4.2 SC V8 Barolo Black
"In fully charged condition @ 11.4~11.5"
That is a very dead battery. Should read 12.6 when fully charged and never lower than 12.4 when doing nothing.
Post #604982 27th Aug 2021 7:24pm
ffrr14
Australia 2011 Range Rover Autobiography TDV8 Orkney Grey
Thats at the starter relay coil Smile
Listening to the workaround I now believe the problem is with the starter solenoid activation circuit, which over time gets out of spec and results in such issues. SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New Toy: Unimog U1550L/37
New : G350D
Post #605000 27th Aug 2021 11:03pm
aids22
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Rimini Red
I had the same problem after changing the alternator. Anybody who has replaced the alternator you will know that it is quite a strip down, disconnecting the battery is also required.
Sometimes pressing the start button would give a click and the dash would go off.
The battery terminals appeared to be tight but as a last resort before buying a new battery I re-tightened them tighter than I would normally think necessary and have had no problem since. It did not make sense to me as they were already tight but it worked.
What happens it that when the starter solenoid powers the starter the massive current draw causes a voltage drop sufficient for the dash to reboot, As soon as the dash reboots it drops the signal to the starter. It all happens very quickly and that is why you only get a click.
Post #605003 27th Aug 2021 11:25pm
TeeMyob
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Just to update.
I have another new starter motor on now.
This one is a Denso.
Post #613354 21st Nov 2021 8:37pm
TeeMyob
Just an update.
The replacement Denso has worked fine.
Seems the Spanish Garage fitted a 3.6 with no breather pipes.
Post #623021 8th Feb 2022 10:44pm
dhallworth
Our 4.4 TDV8 went through multiple starts within the first 21k miles (3 in total) and we all changed by the Land Rover dealer. It then failed on us again in September 2019 at which point I fitted a Denso one that we sourced from Euro Car Parts and it’s been fine for nearly 3 years now.
Hopefully this is the end of all your problems.
Post #623022 8th Feb 2022 11:30pm
