Home > Technical (L322) > Stranded again ! |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 199 |
Have you checked the battery connections are tight? Could be a lose earth somewhere. |
14th Aug 2021 3:46pm |
TeeMyob Member Since: 22 Jun 2019 Location: Javea/Manchester Posts: 193 |
Hi,
14th Aug 2021 4:33pm |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 720 |
The trick to disengage Park is to pull out the cup holders, open the hatch underneath then turn the slotted plastic thing 90 degrees then pull on the red thing to release park.
14th Aug 2021 4:39pm |
Dean_C Member Since: 30 Apr 2021 Location: Lancashire Posts: 41 |
Afraid drive knob won’t raise until started.
14th Aug 2021 4:54pm |
Thanks for your replies
14th Aug 2021 6:03pm |
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 |
you are confirming something I am also experiencing. I have a workaround when that happens, press and hold the starter button then depress the brake pedal. See if this works for you.
14th Aug 2021 10:22pm |
What voltage are you getting on the relay coil? |
15th Aug 2021 1:58pm |
In fully charged condition @ 11.4~11.5. Interested to see how yours might be doing. Remove starter relay, press start then check voltage in all 4 pins.
16th Aug 2021 12:04am |
It was 12volts or more or less whatever in the battery, same for the coil of the relay.
16th Aug 2021 5:43pm |
Thats a reference point for me. Thank you
16th Aug 2021 10:26pm |
Can you share the pin voltage? 1,2,3,5 pls SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC New Toy: Unimog U1550L/37 New : G350D |
16th Aug 2021 10:29pm |
27th Aug 2021 9:17am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1320 |
But for those rocks you could have pushed it into the sea |
27th Aug 2021 9:31am |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 |
At least you have a nice view....
27th Aug 2021 10:49am |
