![]() | Home > Technical (L322) > Stranded again ! |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 209 ![]() ![]() ![]() |
Have you checked the battery connections are tight? Could be a lose earth somewhere. |
TeeMyob Member Since: 22 Jun 2019 Location: Javea/Manchester/Abu Dhabi Posts: 200 ![]() ![]() ![]() |
Hi,
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 738 ![]() ![]() |
The trick to disengage Park is to pull out the cup holders, open the hatch underneath then turn the slotted plastic thing 90 degrees then pull on the red thing to release park.
Dean_C Member Since: 30 Apr 2021 Location: Lancashire Posts: 41 ![]() ![]() ![]() |
Afraid drive knob won’t raise until started.
Thanks for your replies
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 ![]() ![]() ![]() |
you are confirming something I am also experiencing. I have a workaround when that happens, press and hold the starter button then depress the brake pedal. See if this works for you.
What voltage are you getting on the relay coil? |
In fully charged condition @ 11.4~11.5. Interested to see how yours might be doing. Remove starter relay, press start then check voltage in all 4 pins.
It was 12volts or more or less whatever in the battery, same for the coil of the relay.
Thats a reference point for me. Thank you
Can you share the pin voltage? 1,2,3,5 pls SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC New Toy: Unimog U1550L/37 New : G350D |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1343 ![]() ![]() |
But for those rocks you could have pushed it into the sea |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
At least you have a nice view....
