Home > Wheels & Tyres > Do you replace all 4 tyres together? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8160 |
The centre diff is an open diff, same as the front and rear diffs, it doesn't mind different speeds front to rear, it won't wear it out any more... During off road driving, it, and some rear diffs, have the ability to distribute the drive to where it is needed but this doesn't wear the diff. The earlier Range Rovers with diffs that you could "lock" are a different matter... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Parchment over Navy Interior. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand, Jet Interior. Sold 2002 L322 Vogue 4.4 V8 Epson Green, Ivory over Aspen Interior (Fatty Offroader) Sold -Click for Project Fatty off roader- |
10th Aug 2021 4:43pm |
LT Member Since: 13 Mar 2017 Location: South West Posts: 396 |
“I'm with Stan, much prefer the extra tread at the front especially in the wet when the extra tread depth will help stop the vehicle quicker than having more tread at the rear....
10th Aug 2021 5:18pm |
tezza Member Since: 22 Jul 2021 Location: Gloucestershire Posts: 78 |
I'm with haylands, I prefer the new ones on the front where under heavy braking, most of the weight will be transferred.
10th Aug 2021 5:36pm |
There is no argument, it is a proven fact that if you are replacing just a pair of tyres it is safer to fit them on the rear axle.
10th Aug 2021 6:27pm |
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 728 |
Thanks all, stirred up a bit of ‘healthy’ debate too
10th Aug 2021 7:22pm |
[quote=] "LT"Your 2p goes against the advice of all tyre manufacturers and road safety organisations. [/quote]
10th Aug 2021 8:36pm |
10th Aug 2021 11:01pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16263 |
I run several RR's and look after MANY MANY more... I always rotate mine every service point... Then I replace either all four tyres or sell the wheels with 1/3rd tyre tread (on eBay or alike) and replace them with a set of premium tyre'd new take off's... Happy days |
11th Aug 2021 12:17am |
Treebor99 Member Since: 07 Feb 2021 Location: Rugby Posts: 34 |
If any of you have ever tried riding a motorbike with a pair of brand new tyres you'd understand why New tyres should always be fitted to the rear. pretty scary. low grip = low stability / control = bruises and scratches.
18th Aug 2021 10:40am |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2254 |
I replace all four at a time when they are down to 4mm also run winters and summers. Not the cheapest way to do it but I do lots of miles and drive quite hard so think it is worth it |
21st Aug 2021 9:08am |
Jase0851 Member Since: 25 Jul 2021 Location: Uk Posts: 5 |
always replace mine as a set before i read about the diffs so might replace axles in the future |
23rd Aug 2021 1:49pm |
