Home > Wheels & Tyres > Are wheels handed on my 63 plate ffrr
GrandadRob
England 2013 Range Rover Vogue SE SDV8 Luxor
Just read that wheels are marked lh and Rh because they are different. Is this correct please.
Post #604552 23rd Aug 2021 11:15am
Never heard that one.
If it were true, I'd expect the turbines to have different patterns for either side & they don't
Post #604557 23rd Aug 2021 12:04pm
are you talking about tyres being directional? if so they have to rotate toward the front,, ... - .- -.
Post #604564 23rd Aug 2021 12:45pm
GrandadRob
i came accross the mtter on a rr sport website, apparently they said wheels a different desigh, probably tosh, many thanks anyway.
Post #604566 23rd Aug 2021 12:51pm
4434Morrison
United Kingdom 2012 Range Rover Vogue SE TDV8 Santorini Black
As a former tyre depot manager and sales and marketing manager for Goodyear UK, the only thing I can relate your question to is that radial tyres should always be run on the same side of the vehicle, as the radial belts around the tyre under the tread, will have been run in in the direction relevant to the side of the vehicle they were fitted to.
Tyres fitted to the opposite side of the vehicle that the were originally running on could show signs of tread separation, particularly on high performance vehicles. The same applies to van, bus and truck tyres.
Therefore radial tyres should always be swapped front to rear and vice versa on the same side of the vehicle. This is why many tyre fitters will refuse to fit second hand tyres as there is no history of where the tyre had previously been fitted.
A trained tyre fitter will always mark the location of a tyre / wheel assembly with NSF, NSR, OSF, OSR to ensure that the tyre / wheel assembly is always refitted to the correct side of the vehicle, when for instance changing between summer and winter tyre /wheel sets.
The only caveat being that I held the aforementioned positions in the late 70's early 80's and this was the training relevant to the that time, I am now a little older (70), but have always managed my tyres accordingly. 2012 4.4 TDV8 Vogue SE Current
2015 E220 with AMG Sport Pack - Currently driven by my son
2010 3.6 TDV8 Vogue - Written off by my son
Post #604571 23rd Aug 2021 1:27pm
dis-agree with the wheels/tyres going fronts to back as the landrover service schedule states that during the service wheels/tyres should be changed from one side to the other on the same axle..
[remember neil millward?] ... - .- -.
Post #604576 23rd Aug 2021 1:49pm
4434Morrison
As stated Stan,
Those were the rules back in the late 70's early 80's, tyre technology has no doubt changed since then.
You have to however accept that the recommendation you refer to would be misleading IF the vehicle had directional tyres fitted. I am also confident that many of the older fitters. mechanics will swear by the processes they have learnt over many years in preference to what a land rover tech suggests / recommends.
Personally I abide by what tyre companies recommend. 2012 4.4 TDV8 Vogue SE Current
Post #604578 23rd Aug 2021 1:56pm
i cant recall a landrover OE tyre being directional ..thats probably why the that procedure in the service schedule is used.
but i agree that directional tyres ,if needed to be moved on the vehicle for whatever reasons, should be axle to axle same side..
i also grew up in the tyre trade and there are many 'tyre fitters tales'...mostly made up by me... Laughing ... - .- -.
Post #604582 23rd Aug 2021 2:34pm
