![]() | Home > Technical (L322) > 4.4 Diesel very sick |
Mike Edwards Member Since: 13 Feb 2021 Location: Northampton Posts: 226 ![]() ![]() ![]() |
"EGR temp sensor A-circuit high" has been known to cause problems. It's the temperature sensor on the exhaust manifold which can cause the EGR to play up. |
Blankone Member Since: 10 Aug 2016 Location: St Helens Posts: 21 ![]() ![]() ![]() |
Hi Mike, thanks for the response, I did plug in my auto box diagnostic tool and that also brought up the same problem I just can’t get my head around the symptoms it is showing which equate in my mind to something far more serious.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
Hi Blankone
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
I agree with Greg, although mine has only done 80k, but at least half of them with the EGR code showing and it runs fine.
Thanks for the responses,
Just a thought, cheap job, how about changing the fuel filter if you don’t know how long it has been on ??
Worth trying for the cost of one, will give it a go on the weekend, cheers. |
