![]() | Home > Maintenance & Mods (L322) > IID TOOL suspension height |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8389 ![]() ![]() ![]() |
The later ones (yours) can only be lowered all together so lowering access mode would lower normal mode and then you will get problems with the wheels hitting the front arches on lock if you go too low...
Gr4h4m Member Since: 08 Oct 2020 Location: Chester Posts: 88 ![]() ![]() ![]() |
Thanks for the reply, we have the fixed steps but they are still not helping. I was looking for a quick fix I could do at home. Is there a safe amount you can drop by? I was thinking that if it’s total the bags might them be out of the operating window? As in normal mode it’s too much of a drop? |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
Graham
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 697 ![]() ![]() ![]() |
With a Gap Iid diagnostic tool, you can lower the normal ride height - which will lower the the Access Mode height by the same amount.
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Deleted |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2575 ![]() ![]() ![]() |
Thanks for mentioning this. I'll PM the OP. |
Thanks for all of the suggestions, the x-lifter looks interesting, easy install and removal. I will email them |
If you lower the suspension permanently don't forget to inform your insurance that you have modified the vehicle... |
Deleted |
Thanks for all of the replies. I definitely don’t want the permanent drop links the two electronic options look good. |
