![]() | Home > Technical (L322) > No revs |
William97841 Member Since: 18 Jan 2015 Location: Essex Posts: 141 ![]() ![]() ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35648 ![]() ![]() |
accelerator cable broken? ... - .- -.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8541 ![]() ![]() ![]() |
Stan, it's fly by wire, but you could be on the right track, it could be a faulty accelerator pedal..
William, what model have you got, your profile says a TD6...? Pete
jagracer Member Since: 14 Aug 2021 Location: Norfolk Posts: 113 ![]() ![]() ![]() |
My guess, a speed sensor in the gearbox, or the speed sensor/ abs sensor, I think it is the right rear one. |
Sorry guys I thought I changed it. It’s a 2007 3.6 tdv8 |
The funny thing is I left it to cool for an hr then it worked as normal still fluctuated a bit on tick over but still drove. Just drove another 30miles now no sign of it doing it and still no codes on the iid tool |
this member found he had a split hose so i'd check yours,
FYI speed sensor is left rear ABS sensor, if it goes it chucks on loads of faults and lots of warning lights... ![]() __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
Thanks, thats what happens after laying all day under a FL2 trying to fix a dud engine. |
So checked the hoses their all good. Checked the injector values and injector one was 894 and the others in the 950-1095 mark so I think their ok. I was thinking perhaps egrs? |
Have you checked the throttle pedal yet..? Pete
Hi Pete sorry had surgery not been here for a week. So throttle works fine been driving it all yesterday no problems done about 30miles in it all ok….but this morning started it up ran for 10 seconds and cut out like stalled didn’t know autos could that along with all the messages engine system fault transmission gears only (missed abit on that one) parking brake fault and got the code p0191-24 and a generic code u0401-00. Never had the p0191-24 and it’s the fuel pressure sensor stays high which I thought was strange. So cleared faults turned off then on just drove 5 miles and it’s purring it’s sooo weird. |
