Home > Maintenance & Mods (L405) > Big brake upgrade
Likeomg
Big brake upgrade
Is there such thing? I see JE do a kit for 4.5k but wondering if maybe something from the supercharged model etc is a upgrade?
I have a 2015 4.4 autobiography and a history of big brake swaps... just getting into L405 ownership so appreciate your thoughts, did a search and found plenty for previous versions but nothing for 405.
Post #603794 14th Aug 2021 7:15pm
spbee
powerful uk do one
https://www.powerfuluk.com/vehicles/range-...ipers.html
Post #603796 14th Aug 2021 8:29pm
knwatkins
As you have a SDV8, don't you already have 6 pot Brembos? Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #603797 14th Aug 2021 8:32pm
spbee
I hadn't realised that.. only had mine a couple of weeks so jjust been out to have a look... Smile
Post #603798 14th Aug 2021 8:41pm
Yep, can’t fit Much bigger brakes than that in the wheels, it has same braking setup as the 5.0 sc. if you want it to stop a bit better then you can add fast road pads like greenstuff. But be careful with aftermarket discs, I’ve tried using them on previous and wasn’t happy.
For front stoppers on mine it’s currently TRW pads and Gen discs, but when these pads are done I’m going to give the Greenstuff ones a go. There is nothing that can't be fixed with a hammer😜😜
Post #603807 14th Aug 2021 11:39pm
If your brakes don't feel tiptop and you have the 6pot Brembo's already then I suggest you have the system checked over for sticking calipers, both front and rear. If they are all free and working then move onto the quality of the componants? Pads etc etc sir... Thumbs Up
Post #603808 15th Aug 2021 12:19am
knwatkins
I agree with the above. It may be worth doing a full fluid flush/bleed also if you have performance issues.
I originally had genuine LR discs and pads but got fed up of the brake dust.
I've since moved to using a carbon-fibre and ceramic compound pad on my 6 pot Brembos. They are absolutely amazing in terms of stopping performance and best of all, zero dust Very Happy Kev
Post #603820 15th Aug 2021 9:42am
Martin2
Surprised about the comment re brake dust as I’ve been amazed at how little there is compared to every other car I’ve owned. There’s nothing wrong with the std brake, so if you’re not happy then definitely take the advice given. MY23 Panamera E-Hybrid
MY19 SDV8 Autobiography - Sold
Post #603822 15th Aug 2021 11:52am
Care to share the brand details with me please?
Post #603841 15th Aug 2021 1:37pm
marsie
England 2014 Range Rover Vogue SE SDV8 Loire Blue
Would be interested to know too. My wheels are already coated in dust about 20 miles after cleaning and after a couple of hundred miles they are completely black Big Cry Paul
2014 Range Rover vogue se 4.4sdv8 Loire Blue
1992 Range Rover Vogue LSE 4.2 Ardennes green
Post #603844 15th Aug 2021 2:07pm
knwatkins
PMs sent Thumbs Up Kev
Post #603850 15th Aug 2021 4:10pm
marsie
Thanks Kev Thumbs Up Paul
Post #603856 15th Aug 2021 5:28pm
Dave G
United Kingdom 2013 Range Rover Autobiography SDV8 Indus Silver
Would like to know the brand as well please.
Thanks,
Dave. 2013 Range Rover Autobiography 4.4 SDV8
Previous:
AMG C Class
AMG GLA
AUDI RS6
NISSAN GT-R x 5
Post #603858 15th Aug 2021 5:51pm
jagracer
United Kingdom 2011 Range Rover Vogue 4.4 V8 Zermatt Silver
Hi, I used to race Jaguars, and tried many pad/ disc combinations. What I found was that standard pads and discs were quite good until fade set in. Cheap discs were not much better or worse. Goodridge green stuff pads were useless as they faded too fast, and not suitable for vehicles over one and a half tons. Read the manufactures specifications. Red stuff were prone to falling apart at quite low mileages, and wore the discs unevenly. The best I found were Yellow Stuff pads. Good mileage on a set, just check which grade as they change from suppliers. Paget used to do a six pot caliper and pads for endurance racing. The pads had one inch of wear on each pad, two inches of pad to last a wekend of racing. I believe that Landrover did a few uprated pad/caliper sets if you factory ordered them, and had deep pockets. I found that due to heat, racing brake fluid was a must. Ceramic discs run red hot, so any rubber and fluid does not last long. Arriving at a hairpin at 140mph and finding that the brakes have faded out is quite interesting, so is blatting down an alpine pass and finding no brakes. You take your choices and remember the weight you are stopping. atb, Paul
Post #603863 15th Aug 2021 6:50pm
Likeomg
Hi guys, thought i posted a reply turns out i didn't.
Yes looks like the car does have some big brakes, 6 pot(?) brembo's?
I've bought it unseen as im offshore with work but i do know it had a advisory on last MOT for a pad change all around... though it'd be a good time to upgrade if necessary.
I put AP racing 6 pot fronts 4 pot rears on my defender so more of a fashion icon on that car but the performance is outstanding... i know this is a lot heavier.
Post #603946 16th Aug 2021 7:05pm
